Could you mention the flux bin, colour bin and voltage bin of the SST-20 leds? (i.e. a picture of the package label will show that)
Good price btw when 5 pieces are bought!
For small lights, I like start in moonlight since I use my flashlights in the middle of the night and dont want a blinding light. It would be good if theres an option to enable or disable moonlight mode like in the Reylights.
I like the simple UI of some of the Olights - from off, hold button to enter moonlight mode, a normal press goes to memory, and double press to turbo. When on, holding cycles through L/M/H (or ramping, either or).
Nice and simple, then throw all the config stuff up the top.
Amen to that :) My favorite UI so far would be the Sofirn C8F, pretty much similar to the olights, at least in ramping mode which is the only mode I'm using on it since I've got it as it's the most intuitive one, the one mode that made the most sense to me. I have the tail click with mechanical on/off (still has the memory of the last used mode) then the side e-switch click for on/off, hold for ramping, hold from off to moonlight, double click from on/off to turbo and triple click from on/off to strobe (which I could very much do without.. I'd rather have a beacon mode instead of any other disco mode on a light)
It’s what’s stopped me from buying a bunch of different lights - priority one is emitter temp, priority two is UI. I can’t reconcile the Zebralight UI or I’d consider one
So hopefully the S11 is nice and simple, and we can all enjoy a nice 26650 that just works how it should!
