I agree with the OP. That’s why I carry a pitch torch as an EDC.
I prefer to have the tech that can control temperatures and safety of the li-ions. There is something disconcerting about my pants on fire.
Nothin I like better than 7 clicks to change my Q8 button illumination mode. Bring it on!
I like both, the complicated and the simple. I do know what you mean though with all those clicks. I have to look up the UI cheatsheets sometimes too.
What makes these complicated BLF born UI’s great is that the code is free for all. Learn to modify the code and you can have what ever modes you like.
To me that’s one of top ten things this forum has allowed us flashlight freaks to do. Most of us old timers here can remember the days when you only had a few modes but included those d* flashy modes in the main UI. You had to go threw those modes to get back to the first mode. There were no moonlight modes. You were stuck with what ever low mode and flashy modes it came with. We complained and complained but the oversea’s people seem to never hear us. Sometimes the UI started in high, med, low then the flashy modes getting back to high. There were no momentary switch lights that I remember, just clicky switch lights. Some had mode memory some didn’t. It really sucked.
Then tido started the tidal wave that changed it all. Probably the single most important thing to ever happen to this hobby of ours.
I agree that some of these UI’s are challenging but the people here that come up with these UI’s are only listening to what others here have suggested.
There is no perfect UI for everyone unless it be a V11R or Jetbeam RRT01 but I for one am happy we have choices now instead of like in the past where we had no say so. Just what ever modes china decided we needed.
If you prefer the simpler normal modes, then your happiness lies in learning how to modify the code and flashing the driver. It’s really not that hard but does take some effort and reading to learn. It really has made this hobby way more enjoyable for me. I can make my perfect UI just the way I like it.
One argument about changes. It should be time limited so muggles don’t keep pressing to get alien reception.
After power up (screw on the csp), 1 minute to make a change.
I like simple, it’s a flashlight…
D4 is as complicated as I can handle. Anything more, I can’t remember how to use it. Not remembering how to use… it don’t get used.
I have to agree also about the expanding plethora of UI options.
If you know how many times I have sworn at lights that require 2 second turn off tap……
I demand an international UI standard!
High - Low - Strobe?
High - Medium - Low - Strobe - SOS?
I also prefer something useful and simple. I prioritize full regulation over gimmicks.
Do what I do, memorize the UI you like (anduril) and then install new replacement drivers (some of them custom boards) in all your lights so they all run the same UI.
I agree. That’s why I still like to put the A6 driver in my lights. Simple, cheap, bulletproof.
i know it’s all a bit sci fi, why not just go with ramping with memory…but then you find ahh, need to wap on turbo because there isnt time to ramp up, once your there it would be nice to one click back to where you were and then is born ‘modes’, as soon as you get used to 2 things going on, your mind broadens into 3 modes, and finally you get so involved in the whole thing that you loose track of multiple mode types…
it’s a vicious circle isnt it lol…tripple click back the beggining then?
edit in…it’s all gunna need a basic language soon, like a regulated body and set functions to encompass all modder’s into one union and standardisation….theyre going to take us all over!!
I agree. Complicated UI's prevent me from giving otherwise decent flashlights to friends/relatives as gifts. The exception being if there is a programmable UI where I can lock out the user from inadvertently making changes. The last thing I want to hear is somebody calling me back saying they did something and can only go between Moonlight and SOS.
On a personal note, flashlight sizes and function (throw vs flood) usually have specific use cases for us. I don't need my penlight having a strobe. I don't need a long-range thrower with a moonlight mode. I bought an expensive Surefire light for a girlfriend once because it had two modes and was bulletproof. It did what it claimed to do and nothing more.
We also don't need flashlights claiming 5000 lumen, but can only do it for 45 seconds, but that's another rant.
That is when you really notice it, when you give a FL to someone .
I tend to agree, mostly. However, I do like the option to program a light the way I want it. IMO, Zebralight’s new programmable UI has it right. It’s flexible enough to allow you to set up the light the way you want it, but simple enough that you can remember how to reprogram it if you want, without the need to look it up.
I find that UI’s like Anduril and NarsilM go way to over-the-top. Yes, they’re extremely flexible and programmable, but you absolutely need a spreadsheet and flow-chart in order to be able to do it. And even then, it’s often so complex that you screw it up a couple of times before getting it right. With those lights, I usually just give up and leave it on default ramping, even though it’s not quite what I want. So, I’m probably missing out on a lot of the features, simply because they’re too difficult to use.
So, yes, I like the flexibility that the new UI’s provide, but only to a limit. Too much of a good thing is often not good. I like flexibility, but not complexity. Some lights just shove too many features in them, without them really being important enough to warrant the increase in complexity.
I want a Telepathic UI that can read my mind… ON/OFF Tint and what level I want, then I’ll be happy….
hmm telepathic UI, might get tricky lol, a bit like the festal virgin spirit things that do what ever you want, tisnt a blessing, and ermm is it greek mythology where it’s actual an eternal punishment, fair do’s the batteries in a torch wont last quite that long.
I always go back to ZL and olight because of the UI. Same reason my meteors only lasted a week with me. I hate press and hold for off, half presses and tail switches. I keep all my lights similar UI and prefer instant access to turbo or moonlight.
It would be cool if a USB rechargeable light could access the programming in a windows/android/iOS window and set it up that way.
without compromising the water resistance, i’e. the Chinese rubber thong grommet, the one that fits in the hole but that’s about all lol.
I hear what your saying Gebe & somewhat agree. But as long as the UI is user programmable, I don’t care how complicated it is. I just set it how I want it & forget it.
Edit: By “user programmable”, I mean by a few clicks and/or half clicks. Not re-flashing, using a smart phone or computer, saying magic words & Hokus Pockus, or using black magic.
Just a few simple clicks… half or full.
