hmm telepathic UI, might get tricky lol, a bit like the festal virgin spirit things that do what ever you want, tisnt a blessing, and ermm is it greek mythology where it’s actual an eternal punishment, fair do’s the batteries in a torch wont last quite that long.
I always go back to ZL and olight because of the UI. Same reason my meteors only lasted a week with me. I hate press and hold for off, half presses and tail switches. I keep all my lights similar UI and prefer instant access to turbo or moonlight.
It would be cool if a USB rechargeable light could access the programming in a windows/android/iOS window and set it up that way.
without compromising the water resistance, i’e. the Chinese rubber thong grommet, the one that fits in the hole but that’s about all lol.
I hear what your saying Gebe & somewhat agree. But as long as the UI is user programmable, I don’t care how complicated it is. I just set it how I want it & forget it.
Edit: By “user programmable”, I mean by a few clicks and/or half clicks. Not re-flashing, using a smart phone or computer, saying magic words & Hokus Pockus, or using black magic.
Just a few simple clicks… half or full.
There are ups and downs to both. I prefer to have a choice if given a choice. And having the freedom of choice is always hard. But there’s a lot out there if all you want a limited UI as well.
What is _really _needed is an easier way to program the UI - via smartphone app, Bluetooth, USB, whatever. Hitting a button 2000 times to get to a config menu, then another 600 times to get to a specific setting, etc., etc., is not my idea of fun, though I understand it’s the best that can be done with one button. Even having to take a driver out of a pill to flash it can be a pain for a noob. Heck, I find it a pain. On larger lights where there’s more real estate on the driver how about a half-pitch micro DIP switch? A nice 40 cent part to make life easier?
The good thing about most of our complicated UIs is that you can always set them to be as simple as you need. You can’t get more straightforward than Biscotti on mode group 12.
In a perfect world you would order the light with the mode group you want already pre-flashed permanently, but let’s be serious,
the vendors can’t even box the right tint you ordered when the choice was only between 2 variations, cold white or slightly less cold white:)
Sad but true.
That is funny! Thanks for that!
At the end of the original post you seem to indicate that a basic ramping is fine. I suspect your frustration is with all of the additional features and modes. I realize I may be understanding incorrectly.
When I got my Thrunite TH20 headlamp it loved it. A basic ramping interface with memory, as well as shortcut to moonlight and turbo. Is this what you mean by an acceptable ramping interface? The BLF UI is a variation of the same thing. It’s equally easy to use. There’s no need to make it more complicated. However, there’s the option to do so.
The only downside I can see is the accidental activation of an unwanted mode without the manual around to get you back out. Other than that I see no downside to the complexity, which is essentially non-existent until summoned.
it is hard to control a lot of features with just 1 button.
there are lights that have simple UIs but they don;t have a lot of features either.
I wonder if it’s reasonable to expect to one day a budget flashlight have a such feature?
think about the phone, at first we just use it to call, then add messenger, pics, apps……boom, you can do anything via your smart phone but only do several things with it!
something existed is just in case, some are for common use.That’s why we need more lights and more complicated UIs
Bad news is many muggles purchased Q8 because of the awesome driver, but give bad feedback after they found don’t know how to use the complicated UI!
They will say if I can only use on and off, ramp up and down, why wouldn’t I choose a cheaper one or a bigger brand?!
I think the user interfaces could be simpler and have an easy lock feature so no one ever falls into a triple flash mode by mistake.
Sadly most non-a-holics have problems figuring out what a half click is and endlessly hammer on and hammer offdoing full clicks to change modes ...
Alas I hate the hold to turn off a light .It's absolutely non intuitive and fools me into a un nessesary trip around the sequence instead of a simple on and off .I like the user interfaces that after a second or two the next click is ...off ... I also dislike the hold to run thru the modes instead of just a click .
do you mean, click to turn on and change modes, click to turn off after several seconds(let’s say 10s) not using? What if I wanna turn off right after changing modes?
I think best way to make it simple is use two switches. One to turn on / off, the other to change modes.
The Skilhunt H03 UI but without sublevels, strobes hidden deeper, and hold for 0.2s for off would make a tremendous muggle friendly UI even wihout explanation of how it works.
like 3 seconds not ten .. if you click within 3seconds it goes to the next mode . Longer than 3seconds?. it shuts off and restarts in mode#1 at what ever you've set that mode to be . Archeon made this UI and if you held down on the button in any mode it smooth ramped so you could set any mode to any output . It's a very user friendly driver 'cept for it's foul low frequency PWM .
Beyond nostalgia for “the good old days”, I think there is something to be said for hardware controls. Having a physical slide switch or dial that sets the mode could offer a lot of advantages. You’d have an easy way to know and control the mode both before and after you turn on your light. You wouldn’t have to feed an electronic switch. For people who enjoy stuff like automatic watches and “steampunk”, the analog flair would be especially nice on brass models.
I’d love to see something like that with a nice, warm, high-CRI LED from Yuji or Nichia…
I like simple too. So simple in fact, that I do not even like a high/low on my lights when possible. On my Surefire P2X and P3X lights I opted for the tactical tailcaps. Press momentary on at 100% , full press constant on at 100% , press again for off.
I like them that way because I use them that way. The most complicated light I have is my Emisar D4. It is easy to remember all the modes and clicks on it, but sometimes if my timing is too fast I get blasted at close range with a 4,300 lumen bounce back, not fun. I actually like to carry it unlocked and in tactical mode when I am outside after dark. Just press for momentary 100% until my finger burns, about 10 seconds.
