Both of my orders have been shorter then I expected.
While I here,
Lexel. If I want to remove some 7135’s from a Skilhunt driver what order??
While I here,
what do you mean with shorter order, did I miss some parts?
AMCs get the best removed with hot air, or 2 other persons with 2 more soldering irons, guess whats easier,
but with hot air you have to be careful not removing other parts as well including the other side
Lexel, Shipping was shorter(faster) then I expected it to be. I should of said shipping was faster then I expected. You beat orders from China ordered at same time.
Thank You for providing these drivers.
On skilhunt driver I want to remove some 7135s without removing the single channel 7135. I know where the single channel is on the modded drivers you sent. I need to know if the single channel 7135 is in the same place.
just installed in my Q8 a driver from Lexel, great quality and max 7135x15 regulated brightness, also running with anduril!
I also wanted to thank Lexel for all his help when installing the driver!
the usual 21mm for H03 has the single on always on top side
the ones with on down side originate from C8F 21700 design and have it always in that position, but other sizes can be differnt
Any chance you could flash a version Anduril instead of NarsilM?
Its no problem to flash Anduril or Emisar Firmware as the drivers are compatible
Maybe I should have asked “can you sell them already flashed with Anduril or Emisar D4S?” to avoid confusion.
If you can I’d like to order 2x 17mm drivers with Anduril.
Thanks Richard.
hello, am i able to order a 30mm driver for an Convoy L6?
Yes, Lexel will send you a personal message asking you what options you want.
Is there a possibility to tactically use the tail button in the Convoy L6 with Narsil or Andúril as in the Sofirn C8F 21700?
Yes
For the initial power on option you can choose two blinks, turbo or nothing.
Unloco:Is there a possibility to tactically use the tail button in the Convoy L6 with Narsil or Andúril as in the Sofirn C8F 21700?
Yes
this is for NarsilM Anduril I dont know how to change that start up
JasonWW: Unloco:Is there a possibility to tactically use the tail button in the Convoy L6 with Narsil or Andúril as in the Sofirn C8F 21700?
Yes
I got a build of Anduril working with the tail switch by un-commenting this bit of relevant code: // dual-switch support (second switch is a tail clicky) #define START_AT_MEMORIZED_LEVEL In addition I had to use the following fuse value (turning BOD on?) to make it work correctly: -U hfuse:w:0xde:m Now, when I use the tail switch it turns on in the last memorized brightness. Basically, it acts like a normal forward switch but it cannot change modes or anything. It just comes on in t…
L6 30mm diameter driver, NarsilM 2S either Blink at the tail cap or Turbo at the tail cap?
I’m in for 1. Already PMed you Lexel.
Yes
OK.
Thanks.
Interested in one L6 NarsilM, PO=turbo.
I have also made a crowdfunding campaign for the new reflow oven as I will not make the drivers more expensive
First sort of Crowdfunding I try here, to start with latest Gear that I bought making my dri… Stefan Vendel needs your support for reflow oven for BLF drivers
Hi Lexel, I’d need a 30mm 1S driver for a tail-clicky host (Olight M22).
Bistro UI would be cool
sure there is the 24-30mm Bistro 1S possible to build
~~X3~~:Hi Lexel, I’d need a 30mm 1S driver for a tail-clicky host (Olight M22).
Bistro UI would be coolsure there is the 24-30mm Bistro 1S possible to build
Can I get a quote by private message please?
