Ya, too bad HL is not investing more time and money into getting real FET. It could have saved them and their customers from troubles. Based on quantity they buy they can get quite low price per FET. I don’t understand what’s their logic.
I don’t think they knew they were fake when they ordered them but I did tell them to be on the look out and send me a sample to check which is what they didn’t do.
It was not a malicious use of fake components by any means, they just skipped out on the final step that would of prevented it.
I am not going to get into a lot of detail but lets just say there are 2 fractions in the HL upper management. 1 side is good and I support today, the other is classic china business practice that leads to issues like this.
I was just reading all these recent posts with some concern. I just received last week an MT03 TA. If mine has a fake FET driver is there an easy way for me to identify that?
When you say that the fake FET’s are not suitable for extended use it makes me concerned this light will fail shortly after whatever the warranty period is given that it’s not going to be a daily use light.
I’m light years behind you guys in technical understanding and mechanical skill but I’m familiar with working with electricity. I’ve never worked on small circuitry before but don’t want my recent investment and so far favorable purchase to be for not
It seems like the majority of fake FETs are doing their job. Problem signs are if the main leds stay on or if you increase the current through the FET by adding bypasses to the springs. Too much current could make the FET fail completely.
I imagine all these factory drivers have the cheaper FETs. Yours included.
Maybe DENGOH can hold the old FET next to the new one to photo the difference.
Yeah, in most cases the FET will be ok as long as you do not modify the light. Not ideal but ok.
Luckily the ones that do fail are only a $2 replacement FET to fix them. Although that assumes you can install it, but usually you can find a repair shop that can do it for a few bucks worst case.
If you fully charge up the highest drain batteries you have and disable the thermal protection then let it run until the light is ~80-90C it should be a good stress test to see if the FET will fail. If it survives that it is unlikely it will die from normal use.
You should reset the thermal protection after this of course.
I’ll run the thermal test tonight. I have an IR thermometer and I’ll be using fully charged 30Q’s so it sounds like I have all the right materials to complete the test.
I almost just bought one. Understanding the concern and how to mitigate and test for it, from my perspective it’s off my list until the next version is out and gets tested. Haikelite needs to be deliberately careful after all the potential customers they lost already with other bungles, ignorance is not an excuse any longer.
I think the fake has big dot at the bottom left. Who has real Vishay SIR800 and care to share pictures?
These two Haikelite SIR800 giving me trouble right from start without extended use. Notice the dot is big. And I have to really adjust my phone camera angle in order to get clear picture on the printing.
Vishay SIR800 picture that I can find on internet. It has smaller dot printed.
And the Vishay SIRA60 I have bought has smaller dot too.
Tom E, thanks for those pictures. There are a few differences compared to suspected fake SIR800.
1.The big dot on fake SIR800 is printed, I use a big magnifier and confirm that. While your pictures shows it should be engraved.
2.The big dot position on fake SIR800 is higher from the bottom edge.
It could be the older 800's had the big dot because mine shown above date back quite a while. Even in the last 2 years, if I used them, it was to deplete old inventory. I haven't bought SIR800DP's in years because they were first obsoleted by the 404 then the A20, plus the Infineon.
