13665 posts / 0 new
Coscar
Coscar's picture
Last seen: 12 hours 36 min ago
@ PeasFull ………….. hmmmm
Im not a Pessimist …. just an Optimist with a lot of experience
A little John Prine
charwinger21
Last seen: 1 week 6 days ago
Interested in 1 with the LH351D 4000K 90CRI.
There is one part I am not familiar with however. It says in the original post that “An unusual feature is the electronic tail switch. This allows the light to do much fancier things than a clicky switch, yet retains the ergonomic benefits of a clicky tail switch.”
What type of extra things does the electronic tail switch allow us to do that a clicky switch wouldn’t?
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 22 hours 3 min ago
A mechanical tail switch is on or off and uses “off time” or “on time” to determine the action you are making. An e-switch can have hold functions and utilize single/double/triple/etc.-click operations without the light turning off at all.
If you’ve used any of the Emisar or Fireflies lights, its allows for an updated version of that UI vs something like Bistro or Biscotti where its just taps to do a quick power cycle that also changes modes.
charwinger21
That sounds very useful. I’m mostly used to dual switch lights, so I didn’t realize single mechanical switch lights would have an issue with turning off when you switch modes.
Thank you.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 32 min ago
Yeah, a mechanical switch physically disconnects power. It literally can’t keep putting out light while the switch is off, because it’s effectively unplugged. The user interacts with it by connecting and disconnecting power, which makes it a little difficult to do anything fancy.
An e-switch works more like clicking a mouse on a computer. It can be up or down, but in both cases the computer keeps running while you press the button.
Stuff like “hold the button to ramp” doesn’t work on a mechanical power-disconnect switch.
Neodraconic
Last seen: 6 months 3 weeks ago
I’m in for 1
Dannopiano
Dannopiano's picture
Last seen: 1 year 9 months ago
Please add me to the interest list. Thank you! This is my first post ever on here, I’ve been reading forever though. Innocent
mgracia85
mgracia85's picture
Last seen: 7 hours 17 min ago
I am already on the list but can you add me for one more please
I love my wife’s toy poodle
Asian8640
Last seen: 2 weeks 2 days ago
Hello! Put me down for one of each :D. Thank you.
Tofudebeast
Last seen: 1 year 4 months ago
I’ve been lurking for a while, finally joined because this looks pretty interesting. I’d like to be in for one (for now)…
Driver 2
Driver 2's picture
Put me down for one, please.
 XPL HI.
We are what we repeatedly do. Therefore, excellence is not an act, but a habit.
JermsMalibu
Last seen: 4 hours 34 min ago
I’ve been reading up on this light lately (new to the forum); and yup, I think I “need” one. Please put me down for 1. Smile Thanks TK and crew.
Edited to add: most likely an XP-L HI, but possibly the Samsung depending on beam and tint bin.
slimkango
slimkango's picture
Ok, I can’t take it anymore, please put me on the list for two with xpl hi. Thank you!
Thrust84
I’m interested in the Samsung emitter option. Please add me to the list. Maybe the XPL version too
wfp
Last seen: 2 years 4 months ago
Hi,
Please add me on the list for for one xpl-hi. Thanks!
funkychateau
funkychateau's picture
Last seen: 1 week 11 hours ago
teacher wrote:
funkychateau wrote:
Is the summary list of forwarded issues available somewhere in this thread?
Reading these posts will probably give you a general idea.
A
….____….B
……..________……..C
Thanks – it wasn’t that far back, so I actually started with “A” and read everything after.
I really hope the final product will accept a wider range of battery lengths. Nothing to lose by doing that.
BurningPlayd0h
Its a balancing act between fitting shorter cells (how they were designed and sold by the original manufacturers) or longer button-top/protected cells. You always sacrifice some fit on one end of the spectrum for more on the other.
JasonWW
JasonWW's picture
Last seen: 6 hours 42 min ago
I would not group button top together with protected. A button top only adds 1mm while a protection circuit adds 4-5mm. That’s a big difference.
The FW3A should fit flat top and button top (most or all, I’m not sure), but not protected cells.
ogre23
Last seen: 4 months 1 day ago
Just made an account for this, put me down for a LH351D!
Edit: Put me down for an XPL instead!
blinky
Last seen: 2 years 6 months ago
Please put me down for 1 LH351D! Thanks!
teacher
teacher's picture
Last seen: 2 years 1 month ago
From my highly non-technical & less than scientific research Hat , my predictions for FW3A Battery Fitment are…..
  • Most all 18650 Flat Tops will work.
  • Most 18650 Button Tops will (most likely) not work. This will depend entirely on the height of the 'Button Top' installed on the cell... but it ain't looking good for "button tops".. . Wink
These findings are based on the stated Maximum battery length of 66mm for the FW3A. Thumbs Up
Since both pair of my calipers are hiding from me at the moment Facepalm , the measurements listed below are taken mostly from LIION Wholesale & MTN.. with a couple from Illumn & IMR.
Flat Tops
  • Efest 18650 3000mAh Flat Top / 65.02mm
  • Efest 18650 3500mAh Flat Top / 65.25mm
  • Hohm Tech Life 18650 3077mAh 20.7A Flat Top / 65.12mm
  • LG HG2 Flat Top / 65.20mm
  • LG MJ1 Flat Top / 65.0mm
  • Panasonic/Sanyo NCR18650GA Flat Top / 65.30mm
  • Samsung 35E Flat Top / 65.3mm
  • Samsung 30Q Flat Top / 64.85mm
  • Sony/Murata VTC6 Flat Top / 65mm
  • Vapcell 18650 20A Flat Top 3000mAh / 65.0mm
    _______
    Button Tops
  • Efest 18650 3000mAh 18650 Battery – Button Top / 67.1mm
  • LG HG2 – Button Top / 67.0mm
  • LG MJ1 Button Top / 66.8mm
  • Panasonic/Sanyo NCR18650GA Button Top / 66.8mm
  • Samsung 30Q Button Top / 67.3mm
  • Samsung -35E Button Top / 66.9mm
So, in summary; there are plenty of flat top batteries that will fit the FW3A even ‘if’ no button tops fit at all. Beer
raccoon city
raccoon city's picture
Last seen: 4 hours 14 min ago
Now I don't feel so bad about buying flat top 18650 cells!  ;)
I wanted button tops, but couldn't find any for the cells I wanted.
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 51 min ago
Flat Tops
    _______
    Button Tops
KB1428 “Live Life WOT
Yoav.Klein
Hi,
Please sign me up for one more light (for a total of 3 flashlights).
Thanks!
DavidEF
DavidEF's picture
Last seen: 1 day 7 hours ago
raccoon city wrote:
Now I don’t feel so bad about buying flat top 18650 cells!  ;)
I wanted button tops, but couldn’t find any for the cells I wanted.
MOST Flat-top cells will work for MOST lights that claim to require button-top cells, if you put a blob of solder on the top of the flat cell top so it can stick above the wrapper. Wink
disclaimer: I can’t prove this. I just think it’s true. (and it probably is) YMMV Innocent
- The YKK Philosophy
JasonWW
JasonWW's picture
Why make assumptions when Toykeeper has already said the FW3A was designed to fit both flat top and button top?
I think 66mm is the “safe” number so as to assure fitment, but I bet it will fit slightly longer cells. Not 69mm-70mm protected cells, though.
I’m sure we’ll hear more about what fits and what doesn’t fit later on..
alexirc
I’m interested! Looks like a great EDC.
raccoon city
I've heard that as well.
Maybe I should put disclaimer in my signature that says I'm not a modder, and I do not solder.
Firelight2
Firelight2's picture
Last seen: 4 hours 4 min ago
raccoon city wrote:
...Maybe I should put disclaimer in my signature that says I'm not a modder, and I do not solder.
There's something special about having an $8 flashlight that you modded with $80 in aftermarket parts.
It's never too late to start modding! tongue-outlaughingtongue-out
ToyKeeper
ToyKeeper's picture
I’m hoping it’ll fit button-top cells, at least. Earlier prototypes did.
I’m also hoping things will happen quickly. But I’m hearing that LH351D may be delayed longer than expected, because they were apparently not ordered back in December when I thought they were. And it sounds like there’s some sort of difficulty in getting them. So I’m kind of wondering if it would make more sense to use SST-20 instead.
I know it has come up before, which is why I mention it, but what do people think of the idea?
Here’s a very brief summary of the biggest differences:
  • LH351D has a wider, flatter, floodier beam. Probably more lumens.
  • SST-20 has a narrower, throwier beam. Illuminates farther away.
Both can still have hit-or-miss tints depending on the exact bin used.
To be clear, XP-L HI 3D is still a “yes”. If I understand correctly, XP-L HI should be able to go to production as soon as the driver fit issue is worked out. The question is only about the LH351D version.
