Luminus SFT-20-W
11 posts / 0 new
Agro
Agro's picture
Last seen: 10 sec ago
Luminus SFT-20-W
Luminus has a line of flat 2 mm² emitters with 3535 package, SFT-20.
So far they are all colour ones.
But I found several references to SFT-20-W i.e. white.
https://www.luminus.com/applications/stage
https://www.aperza.com/catalog/page/10007922/28848/
http://www.marubun.co.jp/product/system/8ids6e00000057xy.html
So…it may be coming.
I asked them about it but didn’t get any response.
BlueSwordM
BlueSwordM's picture
Last seen: 37 min 52 sec ago
Holy crap.
I wanna have it in the 95CRI config.
JaredM
JaredM's picture
Last seen: 10 min 47 sec ago
This would be truly awesome in 95cri.
https://fundrazr.com/osturaband
No affiliation, just a fan.
LouieAtienza
Last seen: 2 years 8 months ago
Only thing it, unless someone makes a custom DTP star, you’re going to have a lot of fun with the offset LES
Agro
Agro's picture
They have special pads layout so they need special MCPCB.
No DTP but 4.54 mm² cathode…
Bob_McBob
Last seen: 49 min 53 sec ago
LouieAtienza
Agro wrote:
They have special pads layout so they need special MCPCB. No DTP but 4.54 mm² cathode…
I suppose the cathode acts as the thermal path… Also then the PCB will have to be electrically isolated in a typical flashlight.
I’m wondering if you flowed this on a 5050 star with the cathode on the DTP pedestal and soldered the DTP and cathode connection on the star – would center the LES?
Agro
Agro's picture
No. It’s just 0.17 mm off center. So even with stuff like a regular centring ring this should have a larger corona and smaller spot but the same cd as perfectly focused, assuming the reflector is quite precise.
Bob_McBob wrote:
This document is from 2016:
https://download.luminus.com/datasheets/Luminus_APN_APN-002804.pdf
Thanks a lot for that!
So it seems like a never-mass-produced rather than not-yet-announced product. Sad
LouieAtienza
Maybe in a smaller OP reflector. I’m not so sure I’d get a great beam in a larger, precision reflector, without some fidgeting. The specs call for the width dimension +/-.15mm so the emitter could be as much as .24mm off if the SMD package was symmetrical, and maybe up to .32mm if it wasn’t (or even just .02mm off… Big Smile )
ArtieT59
ArtieT59's picture
Last seen: 52 min 19 sec ago
is this happening?
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
Sunnysunsun
Sunnysunsun's picture
Last seen: 1 week 3 days ago
No
