OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
1402 posts / 0 new
The_Driver
The_Driver's picture
Last seen: 17 hours 48 min ago
Rhodium has around 75% reflectivity in the visible range.
Dichroic coated glass reflectors have the highest reflectivity. This is what Wavien used.
Enderman
Enderman's picture
Last seen: 1 day 5 hours ago
Yeah, the only people using rhodium are the guys that make short arc flashlights because the UV degrades other coatings.
Protected aluminum is the standard coating for non-lamp applications, that’s what I bought.
The_Driver
Rhodium is also good if you like to clean you reflector with a cloth (for whatever reason) because it’s rather hard. You still need to be careful though.
HONDARIDER
HONDARIDER's picture
Looks like Mountain Electronics has some Osram Flat White spacers for sale now. Still plan to buy Hoop’s because his are going to come with shim stock for adjusting the beam profile. Mountain Electronics may get me by for a while.
nkresho
nkresho's picture
Last seen: 2 months 1 day ago
Heads up, the c8 style 30-30 gaskets I grabbed from mountain are for the smaller reflector hole. Like on the c8 op reflector. Wasn’t able to use them as is.
BobbyMK
BobbyMK's picture
Last seen: 2 days 16 hours ago
194kcd with CSLPM1.TG in a C8 driven at 7.5A with LD-4A driver.
Interesting result. Almost the same as my C8 with black flat in that made 196kcd but with noticeable bigger hotspot.
CSLPM1.TG / Black flat
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
Enderman
Enderman's picture
But you weren’t driving the black flat at 7.5A were you?
djozz
djozz's picture
Last seen: 1 hour 21 min ago
So that is also double the lumens, so 1300-ish? Nice!
In the meantime I wished for a 5000K version of the NM1 and the PM1. I plan to use the NM1 in the GT-micro but I’m also contemplating giving in a few lumens by using a dedomed XP-G2 S4 3D instead.
BobbyMK
BobbyMK's picture
The black flat is driven at about 4.5-5A with full VTC6. I must say that this led gave me nightmares focusing it and i am not even sure that it is perfectly focused but its the best result ive got so far and decided that 196kcd is enough.
I must add that the black flat is soldered by me on a 3535 board and the PM1 is on 3030 board bought from Led4Power. So almost certainly i lose performance on the black flat just because of my unprofessional soldering job with the black flat Big Smile
Should be close to double lumens for sure, at least from what ive seen from few tests here including yours.
5000k would be nice but i do not mind CW leds so its fine for me. I am not familiar with the micro GT other than seeing it on pictures but i had have dedomed S3 3D and it was very nice warm tint with no green hue whatsoever, it might be nice if you want warmer tint compared to the NM1.
HONDARIDER
Need some explanation from someone more intelligent than myself. I installed a 2mm2 Osram in a Cometa and when I was on max power the light dropped to the lowest setting within 5 seconds. Can someone explain what is happening? Put the XPL-HI back in it and it was fine.
Tom E
Tom E's picture
Last seen: 10 hours 39 min ago
Quick guess - Cometa has a low temp threshold, and the Osram is lower Vf than a XPL HI, so, the amps goes way up - probably too much for the LED anyway, and therefore the heat jumps way up fast, tripping the temp threshold which the XPL HI either can't do or takes longer to do.
djozz
djozz's picture
Other guess: I have had problems with the 2mm white flat in combination with FET+7135 drivers (like in the Cometa). Perhaps it has something to do with the extreme low voltage (lower than any white led before). It may even have killed the 7135 chip but that may also have been accidental.
Barkuti
Barkuti's picture
Last seen: 3 days 9 hours ago
Having problems with 7135s or linears? Switching full regulation is a Innocent way. You may also want to try a low current cell or avoid charging cells to the max. Try and measure first, avoid problems.
Did anyone measured an effective max current value for the CSLPM1.TG in a C8?
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Lothar
Lothar's picture
Last seen: 17 hours 43 min ago
!https://i.imgur.com/1Ai1Xae.jpg!
I still can’t figure out how a rectangular gives such a perfect perceivable hotspot. I though you would have seen pie slices of varying intensity Flat Stare
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
djozz
djozz's picture
You must see it as this: in a reflector light every spot on the light source (the die) is projected smeared out in a circle around the center of the hotspot. So the center of the hotspot receives light from the center of the die, and any circle at a given distance from the center of the hotspot receives the light that comes from the corresponding circle around the center of the die, but smeared/evened out. So the shape of the light source is irrelevant, it will be projected as an sum of evenly illuminated “circles”. This is sort of what happens to the hotspot, but the corona can do things a bit different it seems that in contrast is a bit more dependent on the die shape, like showing “petals” when the die is square.
This is the best I can explain this with the limited english that I know, explaining technical things in a non-native language is pretty challenging.
Lothar
Lothar's picture
Thanks, I think it makes sense Smile
Current Collection:
-X3-
-X3-'s picture
Last seen: 21 hours 6 min ago
Just received some goodies from L4P…
So my B158B now does 290kCd @ 10m with its 1mm² WF and LD-4A driver set to 4,5A
And my Cometa does 285kCd @ 10m with the same setup.
I just love the clean beam of the Cometa. I’ve coated the black plastic washer with some paracord fumes a while ago and it does make some difference !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Marc E
Last seen: 11 hours 5 min ago
X3 wrote:
…I’ve coated the black plastic washer with some paracord fumes…
Looks good, how do you do this? I don’t know what paracord fumes are.
thijsco19
Last seen: 1 day 14 hours ago
-X3-
-X3-'s picture
thijsco19 wrote:
https://www.youtube.com/watch?v=Nksb2RCNsF0&t=5m40s
This maybe??
Yeah, that’s the idea…
I burnt some paracord and I placed the washer right in the black fumes to allow a thick coating to depose on it.
My wife hated me for doing that in the living room of course !
Marc E
This maybe??
I found that fascinating!
Lol, what else got coated?
Does it rub off easily?
-X3-
-X3-'s picture
Marc E wrote:
This maybe??
Yes, a little scrub will remove it easily
Marc E
Thanks Smile I’ll stop derailing this thread now.
EasyB
Last seen: 9 hours 24 min ago
I modded my Emisar D4 with 2 1mm^2 and 2 2mm^2 white flats.
These emitters’ voltages make them perfect to put in parallel with each other. Emitters in parallel always have the same forward voltage, so one can predict the relative currents in each emitter by looking at their voltage vs current plots. From djozz’s measurements: if, say, 6A goes through the 2mm^2 LED then 3A will flow through the 1mm^2 one.
It took me a couple tries to get all 4 emitters centered with no shorts. It pulls 19.5A with a VTC5A measured using a clamp meter. I measured 46kcd.
Yourrid
Yourrid's picture
Last seen: 3 weeks 2 days ago
- X3 –
I have a spare Jaxman Z1 (Cometa) I really want to put a flat white in with a Led4Power driver. How did you get the driver to fit?
-X3-
-X3-'s picture
Yourrid wrote:
- X3 –
The Cometa takes a standard 17mm driver, so the L4P LD-4A fits without modification Smile
The sweet spot for the 1mm² WF is 4,5A while the 2mm² version should be around 7A.
I’ve swapped a 2mm² in mine 2 days ago and adjusted the current to 6A and get a nice 220kCd and a funny wide screen beam.
Yourrid
Yourrid's picture
X3
Dang man! I never got a Cometa because I already had 3 Jaxman Z1’s, but they take a 22mm driver. I need to find a 22mm driver set at 4.5A with a bleeder for an illumination tail cap. Maybe Led4Power will come out with a larger diameter driver…
Barkuti
Barkuti's picture
From what I see in the published data by luminarium iaculator, CSLPM1.TG maxes at ≈10A. Considering the CSLNM1.TG maxed at ≈5.75A in led4power's tests, for the same relationship the 2mm² could be set at 10A × (4.5 / 5.75) = ≈7.826A.
scr79423
Last seen: 1 year 9 months ago
does anyone know at 2A, how many lumens does the OSRAM CSLNM1.TG LED make?
Agro
Agro's picture
Last seen: 12 hours 54 min ago
