but i only see those coordinates in the spotread output not in the spectrum file it saves
I usually just take a single measurement and log the data by piping the output to a file, because spotread doesn’t save all the data in the log. Or just copy and paste the text from the command line window. After first calibrating, use whatever parameters and -N -O > log.txt
Is it likely that the accuracy is device dependent?
This free program Osram ColorCalculator is super cool. I re-arranged the spectrum data into a CSV and imported it:
Here is a SST-20 3000K on high with a frosted optic
CIE plot:
R-value plot:
Some report like babel shows:
The actual program window:
Can somebody tell me how to calibrate the colors on a projector connected to one of those stupid fruit-branded all-in-one desktop computers? At our church, the media computer is a Mac of some sort, a few years old. The projector is connected by HDMI over Thunderbolt, IIRC. The colors are horrible! Blues are over-saturated while reds are badly washed-out. I tried the on-board “monitor calibration” …thing on the Mac, but it only had brightness, contrast, maybe gamma, but no per-color-channel fixing. The projector itself has per-color-channel controls, but they don’t help, so the problem seems to be in the signal from the Mac! The LCD monitors connected to the Mac show colors “fine” though. Just the projector doesn’t. So, I don’t know what the deal is actually. Help?
I agree, it’s a great software for the price
It seems their newest version also supports the TM-30-18 report format, which looks very professional. The latest CT&A also does that.
Does this mean high colour accuracy light source tint mixing isn't really detrimental to their overall CRI, TLCI and such indexes?
Can somebody tell me how to calibrate the colors on a projector connected to one of those stupid fruit-branded all-in-one desktop computers? … So, I don’t know what the deal is actually. Help?
Monitor test patterns may be of help, try here for example: The Lagom LCD monitor test pages
Speaking of tint mixing you can enter multiple measurements and the program will plot an estimate for that too.
Unfortunately CT&A doesn’t appear to support the ColorMunki Photo, or at least i couldnt make it work
Good stuff contactcr! I like that a few more people on BLF have the opportunity to measure the colour information of our flashlights.
* It said (Caution) in the output on some lights/modes but still gave me somewhat reasonable output. Should I be concerned?
From the spotread documentation. I think this basically means any really rosy or green LED will always have the “caution” warning.
If the notation (Caution) is displayed after the CRI or TLCI, then this means that the the spectrum white point is beyond the standard tolerance distance from the black body or Daylight illuminant locus. This may make the CRI or TLCI measurement less accurate, and indicates that the illuminant may be a lower quality source of light.
I downloaded the "White Balance Color Temp Meter" to my Pixel 3 and tried it out. Readings were taken on lower modes, in a dark room, with a sheet of printer paper as the backdrop.
Rovyvon Aurora A8 | Olight S1R | Nitecore TUP, LH351D mod | FW3A (3D) | Nitecore P18, XHP35 Hi swap | Armytek Elf C2 (Warm) | |
Expected | 5000 | 6000 | 5000 | 5000 | 4500 | 4000 |
Test 1 | 4600 | 5320 | 4660 | 4540 | 3810 | 3620 |
Test2 | 4510 | 5380 | 4440 | 4440 | 4300 | 3750 |
Average | 4555 | 5350 | 4550 | 4490 | 4055 | 3685 |
Difference | -445 | -650 | -450 | -510 | -445 | -315 |
I have no source for the Elf C2 CCT and guessed at the expected value. If I shift all the values up by 500, using the average of two readings:
Corrected average | 5055 | 5850 | 5050 | 4990 | 4555 | 4185 |
These now fall within about 150K of the values I was expecting. Taking more samples would likely improve the consistency as well. Very promising!
I dont have any of these lights but the real measured CCT is never even numbers.
For example the Wuben with 5000K 90CRI LH351D: CCT = 4816K
So your numbers could already be closer than you think.
Yes, of course. I know, for example, those 4500K XHP35 Hi LEDs tend to measure cooler than advertised. I mostly want to be able to loosely quantify CCT for my reviews, and for that I think a 250K or 500K range gives people enough of an idea.
Most flashlights have a warmer hotspot and cooler spill. Averaged and integrated over the beam the results are usually spot on at binned CCT.
I might get a good price on a used xrite I1 Pro (looks like the one on the firsts pictures from OP as far as i can see)
Is that one still recommanded ?
Yes. It’s still good for LED measurements although the i1Studio/Colormunki Photo may be cheaper and practically just as good for what we do. I like the Babelcolor CT&A, which doesn’t work with the i1Studio.
That one was cheaper than I1studio /Colormunki Photo so i am testing it now :)
I see in the OP that you were using spotread with -a (ambient), was that with the I1pro ?
I am asking because despite having an ambient measurement cap with my I1pro, Argyllcms returns a "Requested ambient light capability, and instrument doesn't support it." error when i try to use the -a instead of -e
An other question : Do you use the ambient measurement cap (ref 609192) ? If i don't use it the sensor is easily saturated but when i try to use it the CCT seems to be off
If you run spotread.exe -v, what does it say?
The label says x-rite, eye-one Pro, rev D
That is strange. Your meter is only a year older than mine, but mine has firmware 506 and reports Measure Ambient ?: Yes.
Check the meter’s functionality with x-rite’s i1diagnostics: https://www.xrite.com/service-support/downloads/i/i1diagnostics_v4_1_2
This will install the x-rite drivers and you have to go back to argyll drivers manually afterwards from device manager.
If this doesn’t help, contact ArgyllCMS’s creator at graeme@argyllcms.com He’s very helpful.
