Those slots are 12 mm long? I was think'n they were for the std 1.5x6 mm size, but from the pics, they have to be longer than 6 certainly, so probably the 12 mm size you ordered.
The new version looks much sexier to me. Too bad it’s likely way out of my budget, even with the group by discount.
The 2x12mm trit slots will not fit the RRT01 without modification, there a little to long. 2x10mm should fit fine.
More info here with pics. WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion] - #261 by moderator007
Would 2.5x10 trits fit?
Not without grinding. Best I can tell the slots are 2.25mm in width. Seems they intended the slots to fit 2x10mm but the 2x12mm is more common at our usual oversea’s stores.
I’m interested.
Deal is alive - i mailed every email in the list
Interested. But may depend on the price…
Ordered, Thanks Martin
Can you confirm the bezel isn’t glued on the new version?
The bezel is not glued. Came off easily. The part of the head above the ring has a touch of loctite or something on it but, it was still pretty easy to get off. I just wrapped some tape around it and used some channel locks and it twisted right off. You can swap the emitter by just removing the bezel but, you gain some extra working room if you get that part above the ring off.
Does anyone know what the standby current is on the new RRT-01? I heard the previous version drains a full 16340 cell in 2 months.
Hmm, the seller says “pre-order, shipping starts march 15”, and on top of that the site does not like the code: “can not used anymore today”.
So for me at least the deal is not very alive.
Had to be done. Ordered one.
grrrr
seems they again limited a deal to several per day (possibly to prevent deal abuse)
I ask banggood to remove that limitation
what is the tint of the emitter? CW only?
Will try again tomorrow. Is it correct that it is on pre-order atm?
yes
preorder until 15th
Interested
Had another go at ordering today and got it working, thanks Martin!
