Thank you!
I think its missing in post one
Thanks for reminding me. will add it.
OK, I’ve been thinking about the multi-day power outages we frequently have, better put me down for a second one.
My first one is: 1232 Ilumenati
Thanks,
Can I be added to the list too please?
I’ll take a second one as well (Currently #1175). This build continues to exceed my expectations.
I’m 195 on the list. Please add me for one more and thanks for the endless work this has required so far!
Were hoping the port will use a USB-C interface if it don’t drive up the cost to much.
New additions added since 2/24:
1257 Sonofspectrum
1258 Chasealmighty
1259 PickleFuzz
1260 Marc E
1261 el_duderino
1262 teejay
1263 f0xx
1264 f0xx
1265 New_Moon
1266 New_Moon
1267 niktak11
1268 beastlykings
1269 Brinkmann
1270 DBSS
1271 MJLiptak
1272 peteybaby
1273 The_Driver
1274 The_Driver
1275 baldo21
1276 baldo21
1277 Unloco
1278 AguassissiM
1279 AdmiralShyGuy
1280 Ilumenati
1281 peteybaby
1282 chathamh
1283 scdaf
!!! Important Note !!!
Anyone who has expressed an interest in a lantern should verify that their BLF user name is correct in the Interest list by user names link. When the lanterns are ready for purchase the pm’s will be automatically generated based upon the user name in that file so if your name is incorrect then you won’t be getting a pm
This is a one time only check so if your name is correct now then it will be correct going forward. In other words you only need to check once. Note that embedded spaces are valid characters so for example a name having one embedded space is not the same as a name having 2 embedded spaces.
Different letter cases in the user name doesn’t matter. Eg. Userxxx is the same as uSERXXX for the purposes of the pm’s.
If a name needs to be corrected send me a pm and don’t just post it in this thread because it could very well be missed.
DO NOT send me a pm saying that your name is fine.
Thanks
Main post OP updated
I can re-post this in the OP too just after the names list to get attention of any new members join in to add to the list.
Wow, the new lantern owners just keep pouring in. Thanks for keeping the list up to date SigShooter!
Ok that works for me…Thanks!
Done deal!
Wow, the new lantern owners just keep pouring in. Thanks for keeping the list up to date SigShooter! :+1:
My pleasure….and it gives me something to do since I don’t work anymore
I can’t find my name on the List!?
You are at 514 and 1239
No powerbank function, as it would make the build more complicated for the V1.
Just for info, is there a V2 in the works and if so what would be different?
What are the ca. dimensions of the lantern?
So people can search for transport pouches
I like this one for the
BOSE SOUNDLINK REVOLVE BLUETOOTH SPEAKER
15,2 cm x 8,2 cm x 8,2 cm (HxBxT)
Has a little extra space for the charger. Is even tapered, but I don’t know if it fits. (probably a bit to wide)
US $12 New PU Travel Case For Bose Soundlink Revolve Case EVA Carry Protective Speaker Box Pouch Cover Extra Space For Plug & Cables
https://m.aliexpress.com/item/32853843814.html
