I like that idea better!
Interested
Interested
Besides already getting a new emitter put in mine, I now have it broke down and am going to fill in the small detents with some lead. I was taught how to braze with lead by a old body man years ago. He didn’t like body filler and refused to use it. So I think I am going to get those detents filled in. I am sure it will take a bit of work to get it all smoothed out but, I have time and I am in no hurry. Think I will see if I can rid the light of that max brightness detent as well. Haven’t looked at it close enough to see if that will be doable. Not going to try and boost output. It is just fine for me the way it is. No need to give myself a reason to burn through cells even faster.
Guess I will see how it goes. I don’t foresee any problems but, ya never know.
Now available for pre-order on Banggood as well
Would anyone know of a Banggood coupon that would work on this? The price seems good in any case.
I am thinking of getting it, even though I do hope JetBeam will make it in Ti…
Try the M4dM4X deal thread.
Thanks, I just subscribed. I guess I will be receiving a code by email or something?
By PM
Does anyone know, what size trits fit on the RRT-01? Is it 2x12mm?
See this post by moderator007 https://budgetlightforum.com/t/-/47799/261
The post says that 2x12mm are too long and need some grinding. It says that 2x10mm should be fine, but I can only find 2.5x10mm. Anyone who has the light at hand, do you think that 2.5x10mm will fit without grinding?
I asked that question and he replied that the slots are not wide enough.
That does not make any sense at all. Tritium slots that need to be modded to fit tritium vials? What are you doing Jetbeam?
Thanks for all the information shirnask.
Now available for pre-order on Banggood as well JETBEAM RRT01 950LM CR123A Taschenlampe IPX8 LED Lampe Camping Jagdarbeit Laterne Sale - Banggood Deutschland sold out-arrival notice-arrival notice Would anyone know of a Banggood coupon that would work on this? The price seems good in any case. I am thinking of getting it, even though I do hope JetBeam will make it in Ti…
See https://budgetlightforum.com/t/-/55825 for link and coupon.
This is not the place for post LumenMax, see here
I did find 2x8mm trits seem to exist in a few places and 2x6mm at mixglo. I’m going to wait and see how I like the light first since it’s so hard to find an exact fit.
I bought 2x6mm trits locally, it is a size that fits certain bait-locators in fishing.
I think this is a European fishing trend cause I fish and shops around here would not know what you meant and send you to look at gun sights or something.
This is one of those, it tells the fisher that the fish is on the hook electronically, but it also has two trit slots.
Not a fisherman so I would not know exactly how it is employed, I guess it floats above the hook. Or not?
The fishing rod rests on that device and the fishing line goes in that tiny inner wheel. I guess when it senses line rolling it will raise up and possible alert the fisherman in other ways too.
As a kid we just clipped a bell to the end of the rod and I’m not even old enough to begin sentences this way.
I see, thanks for the clarification
I was kind of dumb founded myself as to what they where thinking. 1mm longer slots and 2x12mm would work fine and the size is pretty common. When I first measured the slots I thought they would work, that’s the reason I ordered that size. But the slots are just barely not long enough. :person_facepalming:
I have seen a few post about people using 2x10mm trit vials, so I know they exist, I just can’t find a seller. I think there was a guy on the other flashlight forum that did carry this size, but don’t hold me to that. Have no idea if he is still even in the marketplace area there or not, I don’t visit there anymore.
And no the 2.5mm in width will not fit unless you modify it. 2x10mm is as big as will fit drop in style, of coarse anything smaller will fit also, just not as much illuminated area. I checked with a drill bit at 2.49mm and it will not fit. The slots appear to be as best as I can measure around 2.25mm wide. If you have a rotary tool and a small cutting or grinding bit, It doesn’t take to much effort to fit the larger 2x12mm and the slots are cut in aluminum.
If anybody comes up with a source with 2x10mm trit vials, please post up the source, several people here would probably buy 3 per RRT01.
I have seen a few post about people using 2x10mm trit vials, so I know they exist, I just can’t find a seller….
4 choices it seems
