Simon_Mao
(Simon Mao)
March 8, 2019, 3:22am
396
To: sochi111
following one will be available in one week
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.
Simon_Mao
(Simon Mao)
March 8, 2019, 3:23am
397
what about S9 2500mA version 900-100lm
@Simon , that headlamp looks amazing!
Would it be possible to order with SST-20 4000k?
If so, it would be awesome!
To: sochi111
max output 2500mA
What’s the UI on this? Long press for off, or single click? Will this be available with the 219C?
Maybe, though these are intended for regular non flashlight geeks…
So I am concerned about heat…and cost to an extent…
Last time around I think I managed $16 or something (i’d have to look that up) Best I see is $18
Simon_Mao
(Simon Mao)
March 8, 2019, 3:36am
402
yes,long press for off,and single click to change mode
only CREE XML2 version currently
Simon_Mao
(Simon Mao)
March 8, 2019, 3:37am
403
BlueSwordM:
and i plan to produce charging version soon,
SST20 can be adding in plan
Still, thank you a lot!
I’ve been waiting for a Convoy headlamp for such a long time.
I love your lights’ user interface, build quality, and easy modification.
Is it easy to open for modification?
Thank you again.
contactcr
(contactcr)
March 8, 2019, 3:42am
405
I would love an 18350 tube for that headlamp, instant buy.
Looks like a screw-down bezel on that headlamp? Should be easy to swap emitter/MCPCB right?
Is the driver easily accessible for modding as well?
justanotherguy:
$17.69 including 15%off
I’ll take them. whats the specific ordering instructions
1400ma, correct?
Sparks65
(Sparks65)
March 8, 2019, 4:07am
408
Looks Good, Simon. I’ll be buying a headlamp and an S11 as soon as available!
I was going to suggest that instead of using a hateful little reflector, standard 20mm TIR lenses would be ideal.
They can be swapped easily from narrow-angle to wide-angle in a minute or less, and would blend colors so much better to eliminate tint-shift and “fried egg” beams (yellow center hotspot, blue-white outside spill).
The 4C that’s commonly used in the S2+ has a fried-egg beam. White spill, yellow hotspot. After substituting a TIR lens for the reflector, the beam was perfect, like warm sunlight.
To: sochi111
max output 2500mA
Nice light but it look similar to h03 skilhunt
Anychance you selling host? I’m Looking to use different drivers and led.
oweban
(oweban)
March 8, 2019, 7:42am
411
Simon why do you hate my wallet so much D:
Very sexy, hopefully easy to swap emitters! Agreed with the TIR sentiment; I still need to buy the 5pack to find the one I like the best.
sochi111
(sochi111)
March 8, 2019, 8:27am
412
To: sochi111
max output 2500mA
Wow Simon,
I know I was asking for too much for a centered headlight Maybe later
But that is an awesome light.
Simon_Mao
(Simon Mao)
March 8, 2019, 8:47am
413
BlueSwordM:
Thank you again.
it’s too compact to modify it ,but i can supply special version according to BLFers’ requirements
Simon_Mao
(Simon Mao)
March 8, 2019, 8:48am
415
there are two versions
one 1400mA,other one 2500mA
