yes,long press for off,and single click to change mode
only CREE XML2 version currently
@Simon, that headlamp looks amazing!
Would it be possible to order with SST-20 4000k?
If so, it would be awesome!
and i plan to produce charging version soon,
SST20 can be adding in plan
Still, thank you a lot!
I’ve been waiting for a Convoy headlamp for such a long time.
I love your lights’ user interface, build quality, and easy modification.
Is it easy to open for modification?
Thank you again.
I would love an 18350 tube for that headlamp, instant buy.
Looks like a screw-down bezel on that headlamp? Should be easy to swap emitter/MCPCB right?
Is the driver easily accessible for modding as well?
justanotherguy: Simon Mao: justanotherguy:any chance on codes for 580 lumen convoy s9?
I need 12 asap
what about S9 2500mA version 900-100lm
Maybe, though these are intended for regular non flashlight geeks…
So I am concerned about heat…and cost to an extent…Last time around I think I managed $16 or something (i’d have to look that up) Best I see is $18
$17.69 including 15%off
I’ll take them. whats the specific ordering instructions
1400ma, correct?
Looks Good, Simon. I’ll be buying a headlamp and an S11 as soon as available!
I was going to suggest that instead of using a hateful little reflector, standard 20mm TIR lenses would be ideal.
They can be swapped easily from narrow-angle to wide-angle in a minute or less, and would blend colors so much better to eliminate tint-shift and “fried egg” beams (yellow center hotspot, blue-white outside spill).
The 4C that’s commonly used in the S2+ has a fried-egg beam. White spill, yellow hotspot. After substituting a TIR lens for the reflector, the beam was perfect, like warm sunlight.
To: sochi111
following one will be available in one week
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.
Nice light but it look similar to h03 skilhunt
Anychance you selling host? I’m Looking to use different drivers and led.
Simon why do you hate my wallet so much D:
Very sexy, hopefully easy to swap emitters! Agreed with the TIR sentiment; I still need to buy the 5pack to find the one I like the best.
To: sochi111
max output 2500mA
Wow Simon,
I know I was asking for too much for a centered headlight Maybe later
But that is an awesome light.
Thank you again.
it’s too compact to modify it ,but i can supply special version according to BLFers’ requirements
ok ,add in plan
Simon Mao: justanotherguy: Simon Mao: justanotherguy:any chance on codes for 580 lumen convoy s9?
I need 12 asap
1400ma, correct?
there are two versions
one 1400mA,other one 2500mA
it’s special driver ,
it’s not easy to be modified
Thank you for your suggestion. And I’m ready to launch a lens version.
Simon Mao:To: sochi111
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.Nice light but it look similar to h03 skilhunt
Sorry, I don’t plan to sell the host. Because it’s too compact.
It’s not easy to customize.
[quote=Simon Mao]
What’s the UI on this? Long press for off, or single click? Will this be available with the 219C?
Won’t it be more convenient to use short click to turn it on and off and long press for switching modes?
Ooooh yes!
- single press is on/off
- long press from off is moonlight
- double press from anywhere is turbo
- long press while on changes low/medium/high
Simon, I love that H1:
- knowing your lights - good quality
- knowing your lights - superb value
- moonlight
- always starting low
I’d rather skip the strobe altogether, might be accidentally activated while changing modes.
And High CRI would be a nice option.
There was a big gap in the market below Skilhunt H03 and you’re the perfect maker to bridge that gap.
And 18350 tube is just a superb addition.
How much does H1 weigh?
