【convoy】H4 and B35AM options are updated
Looks Good, Simon. I’ll be buying a headlamp and an S11 as soon as available!
I was going to suggest that instead of using a hateful little reflector, standard 20mm TIR lenses would be ideal.
They can be swapped easily from narrow-angle to wide-angle in a minute or less, and would blend colors so much better to eliminate tint-shift and “fried egg” beams (yellow center hotspot, blue-white outside spill).
The 4C that’s commonly used in the S2+ has a fried-egg beam. White spill, yellow hotspot. After substituting a TIR lens for the reflector, the beam was perfect, like warm sunlight.
Nice light but it look similar to h03 skilhunt :stuck_out_tongue:
Anychance you selling host? I’m Looking to use different drivers and led.
Simon why do you hate my wallet so much D:
Very sexy, hopefully easy to swap emitters! Agreed with the TIR sentiment; I still need to buy the 5pack to find the one I like the best.
Wow Simon,
I know I was asking for too much for a centered headlight Maybe later
But that is an awesome light. :slight_smile:
it’s too compact to modify it ,but i can supply special version according to BLFers’ requirements
ok ,add in plan
there are two versions
one 1400mA,other one 2500mA
it’s special driver ,
it’s not easy to be modified
Thank you for your suggestion. And I’m ready to launch a lens version.
Sorry, I don’t plan to sell the host. Because it’s too compact.
It’s not easy to customize.
[quote=Simon Mao]
Won’t it be more convenient to use short click to turn it on and off and long press for switching modes?
Ooooh yes!
  • single press is on/off
  • long press from off is moonlight
  • double press from anywhere is turbo
  • long press while on changes low/medium/high
Simon, I love that H1:
  • knowing your lights - good quality
  • knowing your lights - superb value
  • moonlight
  • always starting low
I’d rather skip the strobe altogether, might be accidentally activated while changing modes.
And High CRI would be a nice option.
There was a big gap in the market below Skilhunt H03 and you’re the perfect maker to bridge that gap.
And 18350 tube is just a superb addition.
How much does H1 weigh?
Looks like a good idea but totally not overthought. The H03 is compact as well but easy to modify. OK, just don’t glue the bezel or the threads.
BLF version:
  1. please make it 20mm TIR compatible or make a extra TIR model
  1. ad a usable sub 0.5 lumen moon, the current one is too bright for preserving night vision (camping etc.)
  1. use the XM-L2 5D nice rosy tint for the 4000K CCT choice
  1. double press goes to turbo
Seriously, delete that useless strobe mode. It’s as needed as FGM in Africa. Besides the strobe this is a very good muggle UI. Long press shouldn’t be longer then 0.5s however. A good moon/firefly mode is needed for people who don’t want to blind themselves taking a piss at night or don’t want to bother other people. 0.05lm is actually too bright for this.
“0.01%firefly-0.1%moonlight-3%low-30%mid-100%high ,(double-click the switch from off for high); if the flashlight is turned off, press the side switch for 0.5s to enter into firefly mode directly.
Looks great!
I agree with other comments, high CRI would be nice and strobe seems like it could be activated intentionally when changing modes quickly.
Hopefully there’s no PWM like the T2.
Hi Simon,
Many thanks for your frequent participation here and for the great stuff you have for sale. :THUMBS-UP: :BEER:
Some questions:
1. Do you offer the S11 host with SMO and OP reflector or OP only? I would like to order 2 hosts with SMO if possible.
https://www.aliexpress.com/store/product/convoy-S11-host/330416_32973533445.html
2. Do you see any chance to source high quality bin SST-40 in 5000K? I saw you have 6.500K for sale but neutralwhite would be fantastic.
https://www.aliexpress.com/store/product/luminus-sst40-6500k-with-DTP-copper-board/330416_32982326645.html
3. Many many thanks for those L6 switches! I would like to get some more L6 tailcap switches and rubber caps again with my next order. Any chance to get these again? :-)
4. Any news so far about the XHP35 boost driver for L2? Would this driver also work in the S11 host (22mm diameter)?
Cheers,
Thomas
+1 :+1:
Would a red or green light be better for preserving night vision?
Does the switch have an indicator light? Sometimes they call it location or battery power indicator.
Hi Simon, a option for TIR Optik with 30/45 degree would be great. Perhaps to change it later.
Bye Wieselflinkpro
