Congratulations Simon on the first Convoy headlamp :partying_face:
I will probably have a few questions, if they are not already asked by other members
EDIT:
I already have them (questions, suggestions, requests mixed):
- Currently I don’t know, how the headlamp driver works, only the available modes in the UI. Is the headlamp driver is a buck driver (which converts down from 4.2-3.0V of the battery to the voltage required by the LED, without burning off the excess voltage), so it could be also very good at using low forward voltage LEDs for a prolonged time in low to medium modes? Or that driver works similarly (or identically) to the 7135×N (N: 3,4,6,8) drivers?
- To get the most potential out of this headlamp, access to the LED and optics should be relatively easy (preferably, if a driver would need a replacement in the future, that should be also possible).
- I think, support for TIR lens would be essential for this headlamp, as this can give a great customizability over the form of the light beam - my suggestion would be to support the d=20mm h=12.8mm Yajiamei TIR lens, as they offer a wide range of options.
- A few members already mentioned 18350 tubes. I think, if this headlamp would have 18350 tube as well, it could be a great gift for women - especially, if there will be a few more alternative color for the body (I think, the same red anodization as the S2+ bodies, and the clear anodization variant could be a good starting point).
- I would like to share suggestions about UI for the driver, if you would like to consider them
