i owned 1st version, great stuff, this one is even bettery.
guys from YLP really care about stuff and are constantly in touch with forum.fonarevka.ru, discussing features of forthcoming lights right with potential useres. unlike most of manufacturer do.
Almost everything I’m looking for in a high cri headlamp. I want one for hands free close up lighting while doing detailed work and the beam profile and metal tube body (I hate having clamshells/box wear out and break) are great, if only it were a lightweight compact format using aa format batteries (14500 and nimh). When you’re squeezing into small spaces or working at an angle heavier headlamps aren’t as secure and comfortable. Plus aa is in a good spot having just enough capacity for a reasonable session and with nimh compatibility being really convenient to feed.
The high cri aa that is available is the acebeam h40. The beam profile isn’t as suitable but everything else appears to be on point. Anyone know if this is a reliable quality pick? Or if a better option is on the horizon?
Thanks for the excelent review maukka. Looks like a very nice headlamp with a very good price and ui. The only thing holding me back is the IPX6 rating since all my headlamps would get submerged or super soaked sooner rather than later. If they release a Panda 3R with high cri leds and improved driver and ui, I would definitely buy that since they’re rated at IPX8 and cave tested by AEDe.
Just got mine today and am having trouble getting to the sub modes and smooth transitioning doesn’t seem to be any different than normal transitioning. Am I missing something? Did anyone else have any of these issues?
In fact, this feature was added on purpose. During the tests was found a different response of the AMC7138 to the high frequency of moonlight (depending on the batches). So, in addition to the three high frequency-moonlights (5kHz), was added two low frequency moonlights (1kHz and 500Hz), just in case. On some batches of 7138 this will allow a lower brightness of moonlight .
Therefore, you can use one of the three high-frequency moonlight without inconvenience.
Can’t figure out how to change the moonlight mode from the default 6lm to another level.
Press “red” button 20x when OFF to enter hidden pro access
enter moonlight mode
wait 2-3s
press hold “white” button suppose to cycle through different sub-mode, but instead it just cycle between low/med/high
Not sure what I’m doing wrong
Figured it out.
Printed instruction sheet said to only “press-and-hold the white button” for cycling submode which is wrong. The PDF online instruction said to “Click + press-and-hold the white button”. So you are suppose to click once and quickly click/hold.
