Any updates? Official release date?
I wish they used the Boost Hx in the R90TS instead of the xhp35 hi. Would have doubled the throw with similar lumen output
Is it still has no external charging port?
it has :)
Here’s the deal: They could have used 24 XHP 70.2s, ran them at a more reasonable 12V and 2.4A, and produced 100k lumens rather “easily,” while using about 30-40% less power (less heat); AND have enough overhead for turbo.
With 24 leds it will be spec 130k lumens for turbo. Turbo means overdrive to max for these giant flashlight.
Thanks Martin for confirmation. Good to know user can topup battery conveniently.
poor quality
Did they drop it on a hard surface and it cracked?
It kinda looks like 2 pieces that are screwed and sealed together and maybe the screw threads got stripped.
Any more details?
Any more details?
Or, possibly there wasn’t enough meat there behind the threads, causing a catastrophic failure when shocked by impact.
sorry,I don’t haven’t seen the original posts, maybe it has been deleted for some reason.
Translation:“Broken off,I find that the 2 pieces stick together.What the hell is the design.”
poor quality
This does not look like the new model, it looks like the older R90C (pictured below).
Martin’s new video says the MS18 uses heatpipes. Is that true. Looks more and more impressive.
Heat pipes only tend to work well at very high temperatures and are usually a last resort when you can’t get a cooling fan close enough to the heat source. I think it would be very strange if they were actually using heat pipes. Then again, I have no idea what’s going on inside of the MS18 other than it seems to have a single radial fan about 30 or 40 millimeters in diameter. Who knows, maybe it has multiple fans inside.
It looks like the body and head are only glued together.
Those are Allen head screws right above each button. They are hanging down and might have a coating of glue on them.
Locks picture.
JamesB:It looks like the body and head are only glued together.
I’m pretty sure those are screws right above each button. They are hanging down and might have a coating of glue on them.
I think you are right i didn’t see the screws.
Not glued only, there is definitely screws hanging loose on the picture :
looks like a very poor job put together that light ?
No, not really. The construction looks fine.
The question is did it break or did someone just take it apart.
