I don't plan to stock LD-B4HV anymore. I'm not sure about automatic mail sending, so it's better to check site and and this thread occasionally.
Any news on the CULPM1.TG yet?
I really want some of that boost hx
Any suggestions on what to use for a thermal path with an LD-A4 and a S2+ host?
Reading through the thread again I realized I ordered a 12A LD-A4 with the intention or using it for a triple, misunderstanding the use of a MOSFET on this style of driver and don’t have anything to use as a heatsink. It’ll be going in a kiriba-ru triple copper pill, would some of those silicon thermal cubes suffice?
DarkShot, this aluminum spacer is probably meant for such duties. You could also craft it from copper if able, or something similar. The dimensions can be easily figured out, height is the only measurement which can leave a bit of doubt but this is easily solved making the part a tiny bit taller so you can sand down reduce it if needed later.
Cheers, the issue at hand is those thermal kits are out of stock, and if they were in stock they still wouldn’t work, as I’ll need a single hole for the triple pill I intend on using. If I had some machining tools at my availability this’d be done in short order but I don’t unfortunately.
Thanks for the suggestion though!
Still waiting for the FET switches and den 30A drivers :).
My order arrived yesterday! Had everything arrive extremely well packaged, and everything went together almost without a hitch!
Unfortunately it looks like the RGB LEDs don’t like heat or I otherwise ham handed something, ’cause one of them the red channel no longer works and I managed to kill another one. This was 100% my fault, it arrived perfectly functioning. Time to source some new RGB LEDs!
Additionally, where could I add a bleed resistor to an LD-x4 that I didn’t select as an option to use an illuminated tail cap?
LD-x4 doesn't use resistor for bleeder but small jfet transistor 2SK3796 (you will see 3-pin empty space for it on driver - if you ordered one without bleeder option), parasitic current consumption during driver ON time is significantly lower compared to resistor (1mA vs 6-20mA).
But adding ~300Ohm resistor between driver spring pad and gnd ring would work too.
Any new products coming soon?
When they become ready, you'll see them in store.
Hello Neven, is it possible that you will offer XHP50.2 in 3V variant?
Such as from cutter in around 5000K?
I'm not planning to stock Cree LEDs.
I just built a light using the LD-B4 driver and one of your quad pcbs. I couldn’t find a diagram showing the connections of the socket on the pcb. I had to carefully study the pictures of your example build. Is there no diagram anywhere?
I’m talking about the LED PCB. There is no diagram for it.
Edit: see LED4Power answer below
Question: mode advance in the LD-4 drivers is done by a half click, that’s pretty obvious. But is movement in the other direction possible? Eg. by a double click. I can’t find anything about this in the instruction
Double click can be assigned a special function. It’s in the instructions. No reverse
There is no diagram at the moment, for 3x and 4x 32mm mosX boards connections are:
Pin1 - GATE (Pin1 is 1st from the left if you look from pcb center)
Pin2 - TEMP/NTC
Pin3 - MOONLIGHT
For 6x 34mm mosX boards connections are:
Pin2 - MOONLIGHT
Pin3 - TEMP/NTC
If customer buys one of these MCPCBs with all options included, I put connector with wires in package, so customer doesn't need to worry about this, he only needs to solder those wires correctly to driver (red-gate,white-temp, blue or yellow-moonlight).
