I personally like very low duv for warm white emitters after tons of comparisons. For example, I have a Tiara Pro with 4x E21A consisting of 2x2000k and 2x3000k for a 2500k mixed cct and a 4x E21A consisting of 1x2000k and 3x3000k for a 2750k mixed tint. However, the 2750k looks much warmer than the 2500k and everyone I asked thinks the same. The reason is because the 2500k has a very negative duv (rosy tint), whereas the 2750k is less rosy. I think the very negative duv allows our eyes to adapt to the tint much easier so whites appear whiter on the 2500k whereas on the 2750k, whites appear more yellowish tinted. But even the 2750k is probably at least -.003 duv since it is rosier than all of my SST-20 3000k. I’m guessing the 2500k is about –0.006 duv. The tint on the 2500k is absolutely gorgeous and pleasing to look at and use for ambient lighting.
To be clear, I’m not saying Convoy should use direct-drive FET drivers. They’re probably a bit overpowered for most of Simon’s customers. But a “moonlight special” 7+1 driver would be nice. Or something with similar capabilities.
Although high efficiency buck/boost driver would be ideal, I really like this idea of a Convoy headlamp with 7+1 moonlight special for a budget headlamp. Add in Anduril and this could sell like hotcakes.
I agree - a highly efficient driver (and LED that is efficient for its output/tint) would be ideal but I also really like this idea of a Convoy headlamp with 7+1 moonlight special for a budget headlamp. Add in Anduril and this could sell like hotcakes.
This gives a huge advantage because the tint will stay below the BBL, thus being pretty, at all levels, even on the low modes. Recently I’ve organised a group buy for a very-high-cri custom headlamp for some of my friend’s, not real flashoholics or tint snobs, more regular users. Four of them got the 4000K CRI9080+ version, the tint lands on the BBL at on the 300-700lm modes and becomes subtly rosy at 1200lm, so theoretically it should be perfect. Guess what, no one of likes it. They say a 300K warmer (and positive duv) light made the custom look green at any level, and so did the slightly rosy XPL-HI 5D of the D4. It also was noticeably green at the lower modes. And eg. I use my light 80% of the time on the low or medium levels.
Positive duv can be quit yellow at 3000-4000K CCT’s which makes the green colours look more intensive, while negative duv does not and can make wood look rosy which doesn’t look really natural.
The 219C at 5000K has a duv of about +0.003 and it’s horribly lime green, not natural at all.
I made the same observations. A rosy tint does make white look whiter than a positive duv equivalent at the same CCT.
It’s super hard to get these ultra rosy tints at 1A.
Not only are they less bright(no problem at all for me), but absolutely no distributor, or most manufacturers make them unless on a large custom order(5000pcs), and that is without being able to choose flux bin at all.
THIS. It’s a unicorn, it basically doesn’t exist. There is a vocal minority being too particular about this. If people were so repulsed by slightly above BBL lights no one would have any flashlights at all. I probably have 20-30 lights with various emitters and only a few are below BBL at high current even. I want my lights to be near BBL like everyone else but we need to be realistic.
Actually even at higher temps, below duv makes a big difference, just not as much as with warmer tints. For example, I have a huge collection of Cree 5A/5D tint flashlights and they are either below or far below the BBL with duv probably –0.005. If you compare the 4000k 5A/5D tint with a 4500k Cree 4B/4C (above the bbl) tint, they look about the same temperature but whites look whiter with the negative duv 4000k than the positive duv 4500k and much more pleasing tint to boot.
curious, has a group buy ever been done with/thru Simon? Seems like he cares a great deal about end users needs and wants, and knows FLASHLIGHTS. I think the interest in a Convoy H1 headlamp with special emitters and those great UIs would be off the chart.
Do you already know what optics you would like to use? It would be great if it was compatible with Yajiamei optics.
For example with this: Frosted Yajiamei optics
