1. Yes
2. No, you can sub-divide the n- and p-channel MOSFETs into “enhancement-mode” (normally-off) and “depletion-mode” (normally-on) categories (these 4 types have their own schematic symbols). Enhancement-n-channel resists flow (hence the name normally-off), and is the most-often used type of MOSFET. And usually when people talk about MOSFETs, they usually mean a normally-off MOSFET, if they don’t specifically say it’s a normally-on type (since they’re not that often used)
3. That’s what depletion-mode MOSFETs do. A p-channel-enh. MOSFET (which you are reffering to) normally stops current flow the same as a n-channel-enh. Just the “activation method” to let current flow is the other way around. Instead of positive voltage compared to Source pin (positive V_GS) (that’s what a n channel needs), for a p-channel you need a negative voltage compared to Source pin (negative V_GS) to let curent flow.
4. See answer no. 3
5. I’d like to clarify some things here: MOSFETs generally don’t know what a positive or negative voltage is. They have no reference (ground) to be able to tell positive and negative apart. This is just us, that defined a specific voltage potential as “ground”. That way it’s easier for us, and the calculations. What MOSFETs however do know, is “more positive/less negative”, and “less positive/more negative” (the words separated with the Slash are equivalent). It compares the the Gate potential to the Source potential, and acts accordingly.
So to answer the question: MOSFETs don’t care whether the Gate signal is positive or negative, it depends on the combination at the Gate and Source. So yes, all MOSFETs can be triggered with a ground signal.
To easily explain depletion Mosfets: Think that they are like enhancement Mosfets, but a bias is already at the Gate pin, that turns them already on. So you need to go in the other direction (in terms of voltage) to overcome the bias to turn them off again.
And just to avoid some misunderstanding, in short:
(V_GS is voltage between Gate and Source. “Positive” means Gate more positive than Source, “negative” means Gate more negative than Source”)
n-channel-enhancement Mosfet:
normally-off, positive V_GS to turn on
p-channel-enhancement Mosfet:
normally-off, negative V_GS to turn on
n-channel-depletion Mosfet:
normally-on, negative V_GS to turn off
p-channel-depletion Mosfet:
normally-on, positive V_GS to turn off
I wonder….
I see more and more enquires about high voltage drivers. Hyperboost is the only solution out there.
I see that the IC here is rated to 90V output.
What would it take to turn GXB172 to a high voltage driver?
As of now I don’t have any such plans. Now that you’re saying it - a flooder with 3000 lm CRI97 COB would be interesting. Though definitely out of my skills range.
I think I’ve seen at least 4 inquires about it in the past quarter - and that’s it.
Thus far, I’ve built a total of 4 of these—two of the original Rev A and two more of the Rev A2. Sadly, I managed to fry one of the original Rev A boards, so I only have 3 operational right now. I am rather happy with them, but still would like to hack on the firmware a bit.
When I get a moment, I’ll try to get some more pictures of the new builds, along with some measurements. However, I wanted to check in here and ask a question, as my fifth build is currently having some issues: after I power it up, it blinks the LED (at lowish power) 4 times before turning off. My guess is that communication to the temperature sensor isn’t working? But wondering if anyone else ran into the problem / how to solve it.
I’ve got some of the 20mm boards (finally!), and will be doing some builds of those with some new S11 hosts from MTN.
(And yeah, I have had trouble getting my hands on the 47uF 25V recommended caps; 10V and 16V are fine for 6V and 9V operation, but 12V is too little margin. Managed to get a few from Mouser but they are since out of stock.)
It’s been awhile back but I believe the very first one I built had the problem you described. I had used a small amount of solder paste on the 4 small pads and you can imagine what that did when reflowed with hot air with the pads being so small. I tried reflowing it again a few times and never did get it to work properly. I finally reflowed it off and cleaned the pads of any solder, used a brand new temp sensor with just flux on the pads and reflowed. That fixed it. I’m pretty sure it gave me the same 4 blinks then off until I reflowed the new temp sensor on with just flux. I would try replacing the temp sensor or try reflowing the installed one again, maybe giving it a small tap on the top of the head when the solder reflows to get all 4 legs seated. I know it’s a pain being so small but there’s not much else you could do besides replacing it and try again.
The last 47uF 25v caps I purchased came from aliexpress. They were considerable cheaper for the amount I received. They may not be of the same quality and I haven’t used any yet. But I did measure a few at 40 to 42uF. I do need to try out a few before I could recommend them. If they can hold up under the voltage they should be fine.
Might want to tone down the cussing, it is not allowed on this site.
That said, having been working off and on with another member for a driver like this, I can tell you that getting this working at all is WAY harder then it sounds.
LO did an amazing job to even get this driver functioning at all.
I also spent well over $100 on components for the testing and prototyping of drivers based on this IC
I wonder if more people has build this driver for themself? Maybe with firmware avalible for all, we can create some improvement which people have requested, but I do not have enough skill to make modification with open firmware and currently I am happy with basic firmware.
Schoki has been working on a version of this driver that would use a ATtiny85 MCU and thus allow normal BLF firmwares to be used on it for some time now. He has been super busy recently though so not much progress has been made.
Sooner or later someone will get it to work with BLF firmware. The only real question is how small will it be?
the loneoeans firmware is on github on the gxb172 website, so I am thinking if anyone here has skills to modify it to work with narsil or anduril firmware? I will also like to try it with my build to see how we can make it work!
