Flashlight Host and Uncommon Budget Flashlights
Maybe it gets rid of the artifacts at the outer edge of the beam you typically see with zoomies?
Wonder if a wavien collar would fit, or if it’s even any good to begin with
Most likely it is just the reflection of the bezel.
I checked that. It shows up in 2 different pictures from different angles. It definitely looks frosted.
See below.
Hmmm, hang on. This kinda looks like the same picture, just rotated 75°. I bet it is just the really deep bezel shroud making a reflection. Notice the 6 points of the bezel and the 6 sides on the lens? I bet it’s not frosted.
They also have a re-branded Nightwatch IRA w/ 50.2 and no SS bezel:
https://www.ebay.com/itm/2600Lm-DanceLite-DF8-Self-Denfense-CREE-XHP50-2-18W-Powerful-LED-Flashlight-Lamp/264235622566
And some type of larger driver heatsink fin reflector C8 design, looks like kiriba-ru’s heatsink head but w/ reflector, using those uncoated Nightwatch springs:
https://www.ebay.com/itm/DanceLite-C12-CREE-XP-L-Hi-V3-AMC7135×12-4200mA-2-Group-3-5-Mode-LED-Flashlight/264235622592
For some reason, your link did not work.
Here is a fixed link:
https://www.ebay.com/itm/DanceLite-C12-CREE-XP-L-Hi-V3-AMC7135x12-4200mA-2-Group-3-5-Mode-LED-Flashlight/264235622592
Keep in mind Ebay links are only good for maybe 3 months then go dead. Typically.
More digging, presumably this listing means it’s the same lens as UniqueFire UF-1505,UF-T20 - so nothing ground breaking here I suppose.
https://www.aliexpress.com/store/product/1PC-NEW-37-8mm-x-17-4mm-Transparent-Clear-Focus-Convex-Lens-Optical-Glass-For-UniqueFire/613721_32836423622.html
A 348-like light with a lens?
https://www.aliexpress.com/item/High-Power-White-LED-Flashlight-Portable-Flash-Light-Small-Penlight-Mini-Torch-Lamp-Little-Pocket-Lights/32935039418.html
I’m not sure, at the wall it looks like a round spot but the beam itself seems to have spill. Other beamshots clearly show lights with lenses. But 1 clearly shows another light and the others don’t show the light at all.
Too bad the tail switch spoils the look.
JKK70
I have this flashlight! For some month. with xhp70.2 in neutral white and OP reflector.
Anyone seen zoomie host in Sofirn SF30A style but made for 18650 bat only?
I need to find suitable host with smaller glass lenses, 1x18650 tube,anodized threads…
Sofirn SF30A would do but body is to wide for 25,4mm WE adjustable mount :frowning:
Convoy BD04?
It has plastic lens, and while I have nothing against plastic lenses since they will throw further and have clearer die projection than most commercial available glass lenses with LED emitter it does not fit in mine project…
I need glass lens in zoomie(small lightweight and practical zoomie) so that it can hide laser emitter (VCSEL) imperfections or better to say to make them blurry…
This is how VCSEL looks under plastic(acrylic zoomie):
Glass lenses should kinda merge(blur) that imperfections which plastic/acrylic lens perfectly projects…
@luminarium iaculator — have you looked into the Trustfire Z9? Glass lens according to mfr, 1” body diameter, not sure about the anodized threads…. 12 dollars and change at Fasttech.
USB charging in the Ultrafire UF-Z9USB, otherwise the same.
The UF-V3 clearly stood model for the Sofirn, definitely no anodized threads though.
Hi Kikkoman,
Yes it looks interesting but I have concerns that lenses are acrylic/plastic and I can’t see weather it has anodized threads…
It looks fairly well…
I would like that kind of zoomie(or slightly larger) but with anodized threads, glass lens, 25.4mm body, without any gimmick charging ports if possible…
It is very hard to find such one. I’ve been through whole ali and other sites and I can’t find suitable hosts…
Do you mean that you want a low prcision lens?
Maybe a precise lens with dc-fix or a frosted/patterned one is what you need?
Hmmm… Yes… I just need classic glass lenses in small zoomie light(they usually are low precision ones?)…
But that idea of frozen patter from underside of lens or even better on top of the lens looks like a nice experiment. Small round “blur” or “smudge” on top of lens could do…
Guys. Please try the challenge… It is almost unbelievable how hard is to find this below:
“Zoomie(budget smaller one) but with anodized threads, glass lens, 25.4mm body, 1x18650 bat, without any gimmick charging ports if possible…”
I’ve found a handful that tick all the boxes but “anodized threads”.
There is a neat way of removing the anodizing, forget the name bit I have the stuff at home, its a common oven cleaner. Works surprising well at removing any anodizing it comes in contact with,right down to bare aluminium
