Convoy S9 Carbon Fibre & Lighted Switch Fixed
5 posts / 0 new
CRX
CRX's picture
Last seen: 3 days 22 hours ago
Convoy S9 CF SST-40 - SD - 18650 - EL Sw - 1160lm - Rechargeable.
I thought it was a bit silly for the Convoy S9 to have the lighted switch illuminated only when the light is on so I installed a white LED under the switch cover which is always on unless the light is locked out.
I shortened the battery tube and installed a magnetic tail, the magnet is not too strong but just enough to hold the light horizontally.
The original switch boot is covered in some GITD power & silicone mix which also makes it a little firmer to operate.
27mm x 1mm 3K carbon fibre sleeve on head & body and resistor modded for more current.
Charging indicator LEDs can be seen from the side. Driver cavity is potted.
Stock driver/ 1A USB charger unit with resistor mod so still four modes with 0.5s press for On/Off and single click to progress through the modes while the light is on. The UI takes a little getting used to but is tolerable.
Aluminium & Carbon Fibre shell
Luminus SST-20 6500K Emitter
16mm Copper DTP MCPCB
OP Reflector
GITD O-ring & LED Surround
Lockout-able
Shortened Body
Magnetic Tail
Potted Internals, including the USB port
Lighted & GITD Electronic Side Switch
Low - 9lm
Med - 60lm
High - 435lm
Max - 1200lm
Length – 106mm
Width – 27mm
Weight – 125g (with 18650 cell)Convoy S9 CF SST-40 - SD - 18650 - EL Sw - 1160lm - Rechargeable.
Edited by: CRX on 03/14/2019 - 09:37
MascaratumB
MascaratumB's picture
Last seen: 19 min 9 sec ago
Sweet Smile Like the way the switch looks like Wink And turned out great with the CF Thumbs Up
I wish I had the ability to mod this light’s driver; i would get one! The current UI is a no-no!
CRX
CRX's picture
Yeah it’s not the best but not the worst either.
I’ve never liked lights that you need to press & hold for On & Off but the S9 isn’t too bad.
-X3-
-X3-'s picture
Last seen: 4 days 12 hours ago
I wanted to like the S9 but that UI just doesn’t do it for me…
It’s a pity because I love the aesthetics !
Great job CRX, as always !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Slayer1
Slayer1's picture
Last seen: 1 week 21 hours ago
Awesome mod as always! Thumbs Up Beer
