@freeme, do you know if the new throw numbers are correct?
[♛ FreemeGB] 2019 Niwalker Group Buy, Rare Opportunity - MF5SV1 / BK-LR7SV1 / BK-LB11SV2 -【 ACTIVE 】
I also think the usable reflector is actually quite a bit larger.
While the head diameter of the 1st gen was 100mm, it had a 89mm reflector.
With a head diameter of 101mm, maybe it has a more optimized reflector for focus along with a physical larger head(maybe 93-95mm?)
Interested, Had a great deal with the BK-FA30S, Thanks
Interested.
Interested in MF5SV1 if available in NW
Sent.
TIP: Remember to login your Niwalker account before applying my coupon codes.
Need code for MF5SV1. Very interested.
Something went wrong today. I will send them out when it is available again.
Is the only difference between the two throwers the magnetic ring switch?
Yes.
Any fears on the functionality of that ring? The only time I’ve had one was with the Thrunite TN32. Never had problems, but other than that, don’t have to much experience with those.
Niwalker BK-LR7SV1 is a brand new design. It is 16mm longer and has more mass to dissipate heat than BK-LB11SV2.
All replied. Pm me if coupon is invalid or has expired.
Buyers, please login your account to verify your order is in place.
There has been some hiccups on their site, but Niwalker was with me the whole day to address to every single issue. If you noticed any unusual activities, do alert us ASAP.
Fingers Crossed
Interested in the MF5SV1 mini
My order shipped within 24hrs. How is yours?
Mine went out last Friday.
Hey Freeme,
tried to use the code for the MF5SV1 today and the code isn’t working.
Do you know if they’ve already ended this GB or if the codes are just down again?
