Emisar D18 introduction
If I can - why could he not? He can order through digikey 5600pcs per box with a 6 week leadtime….all the same W6 bin that is higher lumen bin than the Cree XP L he carries……
https://www.digikey.com/product-detail/en/samsung-semiconductor-inc/SPHWHTL3DA0CF4RTW6/1510-2261-2-ND/7347034
Arrow even has free shipping for the T6 bin (6wk mfg leadtime also)
https://www.arrow.com/en/products/sphwhtl3da0ef4t0t6/samsung-electronics
I imagine Hank knows better than probably anyone in China where and how to get what parts he wants….even if other manufacturers are unable or unwilling to do so for various reasons. Just wish he would do it - I would love Emisars D4S and D4 with LH351D….
Always good to have competition I think.
Does anyone know why sst20 is use instead of cree xml or other? I understand if cri is required, sst20 or nichia 219b is excellent, but for lumen maxness, why not use cree led or luxeon v2? Or maybe I am not understanding something.
I hope someone can have them in hand to do side by side competition test!!
This looks amazing, gonna be an expensive year for flashlights I think.
Typically for these lights they are looking for something that fits on an XPG footprint. That rules out SST-40 and XML2 since those are larger LEDs and take more space.
Some LEDs have domes that are too big to fit under standard optics: Example: XPL HD
For LEDs that fit under optics we have the following choices:
  • SST-20 - good lumen output, excellent CRI and throw, but can be green-tinted. Also gets hot fast due to low Vf.
  • LH351D - excellent lumen output and CRI, but quite floody.
  • XPL HI - excellent lumen output, throw and tint. But not high-CRI and quite expensive.
  • Nichia 219B - the recent bin used by Fireflies was excellent, but this is an older LED and supply is limited or completely unavailable. It’s also not very bright.
  • Nichia 219C - decent LED, but pretty much everything the 219C does, an SST-20 or LH351D does better.
  • XPG3 - cheap, but inferior to SST-20 in output, CRI and throw.
  • There’s also a few oddballs I’m not familiar with so can’t comment on (Oslon flats would have lower output but superior throw. Not sure what Luxeons would do).
My guess is they chose the SST-20 due to cheap per-unit cost, high availability, overall pleasing beam pattern with good throw, and CRI options. You would get higher output with XPL HI and the light would run cooler, but 18 pieces of XPL HI is expensive and might literally double the cost of the light.
Each optic clearly is in a holder that touches the MCPCB literally 360deg, as with those type of optics, you can’t put any PCB under the optics to put any aux LED, it’s not the type of multi optics that rest on a few legs.
Hank, will you supply different optic choices that people can buy independently to customize their beam profile?
Also out of curiosity, are these single TIR optics taller than your standard Carclo triple optics?
I love that you went the extra mile to condense the LEDs and minimize empty space.
This is an excellent review and summary. Thank you very much for your time to explain to new user like me. This makes a lot of sense and now I understand why sst20 is such a good choice.
It’s probably gonna drop the output really fast I assume, right? It seems pretty small for the output it has. My Q8 is bigger and has 1/3rd of the lumens of this light.
Is there a list to get on to reserve one, or just keep checking the website?
They don’t do lists or sales, I’m sure it’ll be listed shortly on the website.
I just recently purchased a Q8 and, (IMO), it’s a brick and too dang big. This looks more like it as far as size and brightness goes.
That’s the way it goes in our super rapidly evolving light world! :slight_smile:
I wish this had USB-C charging port too. I would buy a bunch of them for gifts because my contractor friends are going to love them. Sofirn was able to add USB-C to the 3x18650 SP-36 so I’m sure it’s doable here too.
A very good-looking light there you have!
I buy guys Convoy S2…that seems to be the best
The problem with adding a charging port is the charger takes space. A major selling point of Emisar lights is they are super-small hotrods. They tend to be as small and short as possible. Adding a charger would make the light bigger.
Hank said on the first page post 6 that it should be available before the end of this month, and for anyone that missed the other part, under $100 US.
Actually Djozz confirmed the 3500k BlueSwordM sourced is actually above the BBL. The GA3 tint bin seems to be incorrect. Kaidomain just posted they got the 2700k JA3 tint bin which is below the BBL. Hopefully it test out to be true below the BBL. Problem with SST-20 is that the tint varies changes tremendously with output. At lower outputs (especially on 18 emitters), it tends to be green so hopefully Hank can source some far below the BBL tint bins.
Yeah. While the GA3 at 1A is nicely under the BBL with a bare LED, it’s not the case in a real life scenario.
I will probably have 1 of each tint before it’s all said and done. Just great. Guess I will have to start working more overtime. I already have 15 Emisars.
Does it have candle and lightning storm modes?
