Each optic clearly is in a holder that touches the MCPCB literally 360deg, as with those type of optics, you can’t put any PCB under the optics to put any aux LED, it’s not the type of multi optics that rest on a few legs.
Hank, will you supply different optic choices that people can buy independently to customize their beam profile?
Also out of curiosity, are these single TIR optics taller than your standard Carclo triple optics?
I love that you went the extra mile to condense the LEDs and minimize empty space.
This is an excellent review and summary. Thank you very much for your time to explain to new user like me. This makes a lot of sense and now I understand why sst20 is such a good choice.
It’s probably gonna drop the output really fast I assume, right? It seems pretty small for the output it has. My Q8 is bigger and has 1/3rd of the lumens of this light.
I wish this had USB-C charging port too. I would buy a bunch of them for gifts because my contractor friends are going to love them. Sofirn was able to add USB-C to the 3x18650 SP-36 so I’m sure it’s doable here too.
The problem with adding a charging port is the charger takes space. A major selling point of Emisar lights is they are super-small hotrods. They tend to be as small and short as possible. Adding a charger would make the light bigger.
Actually Djozz confirmed the 3500k BlueSwordM sourced is actually above the BBL. The GA3 tint bin seems to be incorrect. Kaidomain just posted they got the 2700k JA3 tint bin which is below the BBL. Hopefully it test out to be true below the BBL. Problem with SST-20 is that the tint varies changes tremendously with output. At lower outputs (especially on 18 emitters), it tends to be green so hopefully Hank can source some far below the BBL tint bins.
I will probably have 1 of each tint before it’s all said and done. Just great. Guess I will have to start working more overtime. I already have 15 Emisars.
Just awesome! Somehow I’m really curious whether this beauty also has a red “Noctigon pure copper board” in the tailcap…. because that is just soooo pretty.
