Actually Djozz confirmed the 3500k BlueSwordM sourced is actually above the BBL. The GA3 tint bin seems to be incorrect. Kaidomain just posted they got the 2700k JA3 tint bin which is below the BBL. Hopefully it test out to be true below the BBL. Problem with SST-20 is that the tint varies changes tremendously with output. At lower outputs (especially on 18 emitters), it tends to be green so hopefully Hank can source some far below the BBL tint bins.
I will probably have 1 of each tint before it’s all said and done. Just great. Guess I will have to start working more overtime. I already have 15 Emisars.
Just awesome! Somehow I’m really curious whether this beauty also has a red “Noctigon pure copper board” in the tailcap…. because that is just soooo pretty.
I too am interested in what choice of optics there are. I’m not really familiar with this type of individual optic per emitter. One thing I like about the Meteor (and D4) is the availability of different optics to adjust the beam from a balance of throw and flood (e.g. the Carclo 10621 or 10622) to very floody (e.g. the Carclo 10623 or 10624). Are there similar options for the type of TIR optic that the D18 will use?
Apologies for the long post. Trying to answer some questions all at once…
It really does. Dale makes some insanely bright lights, and when I turn this on at turbo, I get a taste of how Dale must feel. Even without optics, it’s very bright. It’s like turning on 15 to 20 60W equivalent light bulbs all at once. Normally I find even two of those bulbs to be excessive for an average room, but the D18 turns a room into something surreal like in a movie when they want to convey a holy aura or something.
Probably. The MCPCB is screwed into the same piece of metal the switch is in.
Yes, the boost driver components took up a fair amount of space. I don’t have my Meteor apart to compare, but I think the extra space has been converted into additional thermal mass to help deal with the crazy amount of power running through the D18.
I’m not sure there is even anywhere to put aux LEDs. The front surface is packed with white LEDs and I haven’t seen the optics but it looks like there may not be any room for anything else.
This light has no aux LEDs, so the firmware is built without that option. However, RampingIOS V3 and Anduril have the same aux LED controls so it makes no difference which is used.
OTOH, lightning mode would be fun on such a bright light.
Probably not, but I’m still trying to confirm that. I’m not sure if Hank is willing to change the UI significantly from previous Emisar products, but I made Anduril available just in case.
I don’t think Hank plans to use Anduril, even though I keep asking him about it. He’s probably sick of it by now.
In any case, when I update things in Anduril, I also apply those updates to RampingIOS V3. So it has received several updates since the D4S was released. I’m not sure it will make a meaningful difference to anyone, but it has at least received bugfixes and some small UI tweaks.
Also, XP-G3 makes an ugly rainbow beam.
Yes, it won’t sustain 14,000 lumens for extended lengths of time. Something this size simply can’t soak up and shed 200W forever, because physics. The batteries can’t sustain it for a long time either, because it’s an awful lot of current coming from each cell. I’d estimate the maximum turbo runtime at about 10 minutes, with water cooling. But without cooling it’ll step down sooner to protect itself.
It’s a pretty well-tested setup which has worked fine on many lights for years. In this case, it ramps down to a moon mode of about 1.7 mA, which should provide a runtime of about 9 months per charge.
Sometimes I use car headlights as a unit of measurement, because it’s something most people are familiar with at night and it works out to a nice round number.
The D18 is similar in brightness to 14 car headlights all pointed at the same place, except the beam should be more focused so it looks more intense.
It also has lower modes though, for the times when we don’t want to blind anyone. ~0.2 lm to ~14,000 lm, in a smooth progression of 150 levels. To select one, simply hold the button and then let go when it reaches the desired level of brightness.
