Test/review of Samsung INR21700-40T 4000mAh (Cyan)
84 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 day 4 hours ago
lumiere wrote:
Bought two (subpar) Samsung 40T from imrbatteries.com. Suffice to say, I won’t be buying from them again.
Samsung 40T battery #1:
Charge test (Opus BT-C100): 3511 mAh discharged
Internal resistance (Opus BT-C100): 106
Charge (Xtar VC4): 3566 mAh
Samsung 40T battery #2:
Charge test (Opus BT-C100): 3691 mAh discharged
Internal resistance (Opus BT-C100): 88
Charge (Xtar VC4): 3883 mAh
Also bought two Samsung 50E in the same order, but I’m still testing those (will update with results later).
Let IMR know right away so they can check their stock. If counterfeits came in, I’m sure they don’t want any more to be sold, etc…
shadockan
shadockan's picture
Barkuti wrote:
JasonWW wrote:
SKV89 wrote:
I think the VTC6A might be a slightly better battery than the 40T just like the VTC6 is better than the 30Q. Mooch rates the VTC6A at 30A continuous. I hope HKJ can test the VTC6A soon so we can have it in the comparator
Wow, you’ve been on a 21700 buying spree! Party
There’s something about this statement that seems off “just like the VTC6 is better than the 30Q”. I remember some folks talking about how the vtc6 degrades faster or something. So I would put the 30Q as being the better cell. At least by a small margin. I can’t find that conversation. Do any of you guys remember this?
I agree with JasonWW. For me the VTC6 is not better than the 30Q. And when you consider actual OEM cell prices, Murata/Sony can lick my bird. Sony is not shy of providing peak temperature cut-off discharge ratings even sacrificing cycle life. Like VTC4’s being rated 30A, but they’re not 30A continuous. Of course this makes their figures bigger, though this does not make their products necessarily better.
Source: Bench Test Results: Which lasts longer? VTC6, 30Q, or HG2? @ E-CigaretteForum
Party
Barkuti…..
I totally agree with you
A manufacturer, MANUFACTURING something to have some performance.
This is determined by some limits set by a manufacturer.
If I exceed these limits, then we are not talking about yield that exactly matches the construction.
We are talking about off-limits.
If it is possible or not to operate outside the boundaries of a construction, it is something else.
- My car can reach 200klm / h – 6300rpm.
On the downhill will reach the … 300klm / h – 10000rpm.
But at some point the engine from high pressure …. will break ….. –
This means that an engine has some tolerances.
If Mooch or any Mooch states that such a construction has such a performance, it simply tells his opinion.
My opinion is different about why something was being fabricated and what performance this construction took.
Personally, I will read Henrik’s opinion, because Henrik’s temperatures are the same or very close to manufacturers’ statements.
The differences between batteries today are small.
If I get from a battery 3.5 Volts, and from another battery 3.45 – 3.48 Volts, I think I will want to fool myself because I like the ….. brand.
I think it’s right to compare the overall performance of a battery, resulting in …
force
duration
life
as an overall combinational image
Not just based on how many Amps it was able to perform on a discharge.
Clear only my opinion …..
SKV89
Last seen: 14 hours 1 min ago
I purchased 5 LR2170SF at 18650batterystore.com after reading Mooch’s review saying it is the best high capacity 21700 to date outperforming the LG M50 and Samsung 50E and 50E2
Here are my capacity measurements:
Cell 1: 4,782 mah
Cell 2: 4,714 mah
Cell 3: 4,698 mah
Cell 4: 4,524 and 4,566 mah (measured twice)
Cell 5: 4,834 and 4,870 mah (measured twice)
They are only being sold for a super bargain $5.99 right now. I also tested them in the Fireflies E07 and the LR2170SF outputs higher than the Samsung 50E and LG M50. Get them before they sell out or price increase!
HydrAxx
HydrAxx's picture
Last seen: 7 months 1 week ago
Cell 1: 4,782 mah
Cell 2: 4,714 mah
Cell 3: 4,698 mah
With which “charger/discharger/analyzer” did you perform the Lishen LR2170SF cell test capacity measurements? SkyRC MC3000?
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
BlueSwordM
BlueSwordM's picture
Last seen: 3 days 21 hours ago
Maybe he used a constant current load?
HydrAxx
HydrAxx's picture
I’m not sure, I have a strange presentiment, let him answer thank you, if I’m right I explain why I asked my question this way and you’ll understand quickly …
BlueSwordM
Same thing for me Smile
SKV89
Xtar Dragon VP4 Plus
Cell 1: 4,782 mah
Cell 2: 4,714 mah
Cell 3: 4,698 mah
HydrAxx
HydrAxx's picture
Cell 1: 4,782 mah
Cell 2: 4,714 mah
Cell 3: 4,698 mah
Ok thanks for your quick answer, why else did you do this measure of capacity twice on certain cells in particular? And did you change the test slot during the second capacity measurement of these cells? If no, what slot number of XTAR VP4 Dragon did you use? N1, N2, N3 or N4?
SKV89
HydrAxx wrote:
Cell 1: 4,782 mah
Cell 2: 4,714 mah
Cell 3: 4,698 mah
I measured those two twice because the numbers seem either too low or too high so I wanted to confirm it. I can’t remember whether I remeasured them on different slots or which slots I used. But I don’t think the slots matter because from my testing, most of my other cells were very consistent.
HydrAxx
HydrAxx's picture
SKV89 wrote:
HydrAxx wrote:
Cell 1: 4,782 mah
Cell 2: 4,714 mah
Cell 3: 4,698 mah
However, there is a fairly common problem that is revealed with the wear and regular use of XTAR VP4 Dragon (I am at the 3rd replacement of my VP4 Dragon, although I also have a SkyRC MC3000 (which also is subject to this type of problem with wear and time unfortunately, it is not specific to XTAR) and ZKETech EBC-A40L (much more reliable have no problems, but for a device that costs a little more than 180 usd I think it’s normal)), so the recurring concerns are the even-numbered slots, ie the slots 2 and 4 which with the time of use and the wear, end up having a reading wrong measures, which give either too low or too high results, which therefore push us to often re-perform the various tests by bail, but gives again erroneous results too inferior or too high, the only solution being to operate the Charger/Analyzer warranty if it is still running or buying a new one (I know something Crying …).
Spartan
Last seen: 3 days 5 hours ago
HydrAxx wrote:
JasonWW wrote:
It’s better to calm down. Nobody it trying to get you. We are just trying to learn. We flashlight guys don’t usually learn of a new battery until it’s available for retail sales so we can be a bit behind the times.
Do you have any idea of the difference between the 50G and 50E? Maybe they are the same battery just sold to different markets? I really can’t see any difference. They should both have the same capacity and current output.
That’s what a technician from QB told me: The 50G and the 50E, differs from each other by their respective chemistries which are different as well as their lifetime (depending on the discharge levels in amperes , depending on the use their life cycles will be different). Otherwise, yes for the specifications in general they are the same for both: Nominal 5000mAh and 10A continuous discharge. The 50E is officially intended for use in electric vehicle batterypacks (in short, they are certainly optimized for this use).
I was going through the chart supplied by the OP and noticed a strong correlation between discharge rates and storage capacity. Probably the same thing for recharging lifetimes.
Interesting to me because I have some second hand li-ions that top out somewhere in the 1800mah. I’m in the market for new cells, but can’t make up my mind if I should buy the highest amperage batteries or more higher mah. Then the question, do I care if the lifetime is measured in a few hundred cycles.
Obviously, there I’d too much temptation to max out the light output.
Given history…..after much thought and consternation…I will buy the cheapest.
Once again, a thanks to the OP for his great work for testing all these batteries.
Moses came from the mountaintop carrying a tablet. The Words were....WITH GREAT LUMENS COMES GREAT REPONSIBILITY.
SKV89
I swapped the Cell 4, which was tested at 4,524 in Slot 1 into Slot 4 and it measured 4,520 mah. Slot 4 is where I measured Cell5 at 4,834mah. Therefore this rules out the potential problem you suggested.
HydrAxx wrote:
SKV89 wrote:
HydrAxx wrote:
Cell 1: 4,782 mah
Cell 2: 4,714 mah
Cell 3: 4,698 mah
JasonWW
JasonWW's picture
You don’t want to generalize too much as far as discharge rates in relation to capacity. You also have to factor in age. Batteries designed many years ago, like 8 or 10, are not comparable to newer batteries. The older cells had less capacity as well as less discharge capability. Like the 2012 Panny B 3400mah with a 5A continous discharge rate and the 2016 Panny GA 3500mah with a 10A continuous discharge rate. Both cells are almost identical in capacity, but the GA is a newer design/chemical mix with much less voltage sag.
As far as charge rates, they can vary a lot. Usually a high drain battery can charge at a higher rate than a high capacity battery, but not always. You really have to look at each batteries datasheet to see what charge rates are recommended/safe.
Keep in mind that 200 cycles (low), if charged once a week, equals 3 years. It’s not like the battery is dead or useless after 3 years though, it just typically has a reduction in capacity of maybe 20%. So I really wouldn’t worry too much about the cycle life. We may have a whole new batch of high capacity, high discharge batteries come out in the next few years that we’re going to want to upgrade to.
SKV89
I just tested two Vapcell 40T (gold wrapper) and got 4,101mah and 4,156mah, which is an improvement from the older Vapcell 40T (gold wrapper also), which measured 4,038mah. I’m thinking the current batch uses the production 40T, whereas the older batch uses the preproduction 40T.
Tendou
Last seen: 9 hours 4 min ago
40T or 50E better for Convoy S21A?
Barkuti
Barkuti's picture
Last seen: 1 day 7 hours ago
If you mean a stock S21A with “SST-40 6A” driver, the 50E is better suited. With slightly more drain the 40T starts having an edge, and only in high mode. 40T mostly makes sense for a heavily modified flashlights with high current drains.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Tendou
Thanks! I mean the stock one
JasonWW
JasonWW's picture
You can look at both batteries on HKJ’s comparator and see that at 6 amp the 50E’s advantage starts at around 3.5v. At around 2A or 3A its advantage starts at around 3.7v.
So if you want maximum runtime and regularly run it down well below 3.8v then the 50E has the advantage. It will give longer runtimes. If your like me and only run your cells down to 3.7v-3.8v and then recharge it, you won’t see any advantage to using the 50E. It’s really at the lower voltages that you see the 50E advantage.
Barkuti
Barkuti's picture
JasonWW's points are worth considering too Tendou. In essence it all comes down to how do you intend to use your flashlight, be it in long continuous runs at some mid power level or mostly short bursts on high, and namely how will you manage its battery. I don't recharge often and also don't fully charge my batteries, I focus on cell lifespan versus having cells full or near fully charged at all times. With this in mind the 50E would make more sense for me.
Another thing to consider is how the flashlight driver works. Boost drivers, for example, make use of most of a cell's capacity and energy without tapering down output power and thus it all comes down to selecting the highest capacity cell which meets the torch's current demands without problems.
Fri, 03/27/2020 - 03:48
pirate joe 22
Last seen: 19 hours 13 min ago
How many amps can a fw21 ×9L take ?
What is that led ? SBT 90.2 ?
What’s the best 21700 for that light ?
FlashPilot
FlashPilot's picture
Last seen: 20 hours 44 min ago
These cells just keep getting better and better. As most enthusiasts are already aware, version 3 of the INR21700-40T is in circulation from several resellers and are rated for greater charge cycles than its previous versions. This is one tough cell.
The cheapest genuine cells I could find from a US supplier is at Aloft Hobbies, and Ive purchesed several from them. While their stock photo does not reflect current stock, I just received a qty of 20 that are v3.
JasonWW
JasonWW's picture
Here’s some info on that led.
https://budgetlightforum.com/node/71340
It’s basically a high amperage 3 volt LED. It can easily take 20 plus amps.
The best battery for that light will depend on how you want to use it. If you only use it a few seconds at a time and you want the absolute highest output (on Turbo), then you want to use a very high drain battery. It will pull the highest amps, but get hot very quick.
If you don’t really care about getting max output (on Turbo) and instead want it to run a little bit longer before getting hot, you can use a much lower drain battery. It will pull lesser amps.
This Samsung 40T is a nice middle ground battery.
The 30T will pull more amps.
The 50E will pull less amps.
