First of all, he’d need 18,000 of them for 1000 lights. And quoting Zebralight when I had a conversation with them earlier:
The SPHWHTL3DA0GF4RTS6 you bought comes with 4 possible sub tint. Samsung ships whatever sub tint out of 4 to its distributor (the distributor has no say in terms of the sub tint when placing orders). The chance of getting a good tint from the SPHWHTL3DA0GF4RTS6 order code is less than 30% but the possibility exists. There are 16 possible sub tints with the (4000K, 90+ CRI) order code for the LED we use in the SC64c LE. However, we picked the best one (T6) out of all 16 from our Samsung distributor. We don’t know if you can get the same T6 (or T7) in the future, and hence the ’LE’ part in the model number.
ZL only needs 1 emitter per light, Hank needs 18. If ZL is concerned about consistent supply, Hank even more so. Who knows, maybe it’s not as bad as ZL says. I just sent off for a quote to Arrow for 6400 of the T6’s. We’ll see what they say if they reply.
If an 18350 tube were available, I’d buy one, but I doubt I’d actually use it much. It looks to me like this light would feel unbalanced with that short a tube. (I do use the 18350 tubes on my D1 and D4Ti all the time.)
Either way, I think I’ll be ordering one of these as soon as it goes up on intl-outdoor.com.
This light is incredible. I had absolutely no plans to spend $100 on a flashlight, with the FW3A coming (hopefully) soon, but those plans may have to change.
Thank you for your interest in Arrow.com. Below is the quote you requested on 3/14/2019.
PART Lead Time(Wks) QTY PRICE TOTAL
sphwhtl3da0ef4t0t6
Samsung Electronics 6 6400 $0.8154 $5,218.56
SUBTOTAL: $5218.56
at $ 0.80 they are almost the same price as the SST-20 in the same qty….arrow even has free worldwide shipping doesnt it?
Now - I don’t expect for Hank to even want to order enough for a 1000pcs of 18 emitter lights….Look at the stock numbers on his site. He has around 50 of Emisar D4 ,150 of D4S and 60 of Noctigon M43 in stock….of ALL emitter types……You could build 300 Emisar D18 lights and have a 1000 leds left over to make additional D4 and D4S Emisars!
I just think this is a case of where it may really be worth it….Dale used the W6 bin LH351D on his fireflies and is well over 10000 lumens - a massive gain….so i get it - its not for every situation, but for raw power - its your huckleberry.
LH351D is brighter than SST20. It produces more lumens.
However, my personal experience is the SST20 looks a lot more impressive. Especially in lights like this with tiny optics. This is because the hotspot is much, MUCH more intense with SST20, even if it isn’t as wide.
Best would XPL HI which throws like SST20 while producing lumens like LH351D, and can do so with excellent tint below the black body line. However, I can see why XPL HI would not be a common option in this light, especially if it would double the cost of the light to nearly $200.
[quote back from Arrow]
(https://i.imgur.com/4WSBkgS.jpg) a few minutes ago. The caveat is “pricing and lead times are subject to change based on the factory/supplier conditions” . In other words, no firm time frame. Couple that with Zebralight’s message.
But I agree, if he could get them, spreading them across the other models would be great.
My experience with the XP-L HI wasn’t that great. It showed significantly more abrupt CCT shift in the beam then either my 219C or SST-20. The color temperature was also about out of spec. to. I had a 2700K model, and it’s actual CCT was over 3000K. The yellowish rings in the beam were in the upper 2900K range.
The SST-20 delivers its promised CCT better then the XP-L, and it has far less chroma shift about beam to.
The 18350 proportions look off to me. Functionality wise, if you are carrying such a big light, may as well use 18650’s and have a good grip on the light.
On the other hand, I suspect alot of people would want to buy the shorter tube for a few dollars extra as a secondary option. I would be curious even for myself! Could make a cool table top lantern. That would actually be a good accessory for it, a lantern diffuser made to fit.
