XP-L2's in the SP36 draw more amps than XP-L's in the Q8, have a lower Vf, so should get hotter. Your Q8 is probably fine. Yes, Q8 has a super thick shelf, bigger, more metal host - should handle the heat better, little longer.
Sure, but the difference seems to be too large to be attributed to that alone. Also, not only does it reach higher temps, it starts getting warmer much sooner after I turn it on than Q8. That tells me that thermal conductivity is better in SP36.
Still I’m sure it is not a worse heat path in the Q8, it is thermally one of the best lights around and the way it is built, even in assembly there is hardly a way to screw it up.
I think that you underestimate how much more metal is in the Q8, it has a higher heat capacity so it warms up (and cools down) more slowly.
Again as evidence, my stock SP36 did 6800-6420 lumens - about 1000 lumens higher than any stock Q8 I've tested -- main reason: XP-L2's. The Q8 XP-L's are V6 and I assume the SP36 XP-L2's are also V6, if so, the SP36 must be pulling more amps.
I was not able to detect a difference in lumens between my Q8 with 30Qs and SP36 with VTC6. Looks like buying VTC6 was a waste of money, 30Qs are just as good even for powerful flashlights.
I get consistently higher output #'s on VTC6's vs. 30Q's in many FET based lights. Not just 1 or 2, it's every light - factory FET based, or modded, I've tested - dozens. Whether you notice it, is something else. Comparing a Q8 and SP36 is different LED's, different tints, somewhat different beam patterns.
Not sure what "TA calibrated" means. I have one of the "original" PVC based measuring devices made by the brothers Rick and Rodney. Those #'s are my typical calibrated measurements I've been positing here on BLF for about 5 years or so. I re-calibrated it using the maukka calibration lights and figured the results are 12% lower than my previous calibrations based on manufacturer spec'd lights - 100's.
So just subtract 12% from my #'s and you got maukka ANSI calibration.
I made one from the clear plastic cap on a laundry detergent bottle. Sanded the inside to frost it and put white paper at the bottom (top?) to reflect light towards the table. Works pretty well at about 1,000 lumens.
I am a bit disappointed in sofirn, i bought an SP36 almost 2 weeks ago on their AE store and it showed as ‘in stock’
Next day i received a tracking number, but until today no result, so shot them a message, their reply was, sorry the item was not in stock, we will ship as soon as we have it on stock…
@kawiboy, Nice to read you got it open that easy! did you use that bended bodkin, or what tool is it?
Did it require much force? Did you need to heat up the light first? Did you need to push through the button hole? It’d be nice if there’s an easy way to get the driver out.
It was a while ago, but I believe I went thru the LED wire holes with a solder pick, poked the driver loose - no difficulties I recall, but I've done it this way many times on glued up drivers. Sometimes it needs light taps from a hammer, but the solder pick is not a very rigid tool - mine is a bit bent up from abuse over the years. In general, I always keep the solder pick to the outer edge of the driver to minimize potential damage. 99% of the time there's no damage, most of the time gentle force is enough.
