Still I’m sure it is not a worse heat path in the Q8, it is thermally one of the best lights around and the way it is built, even in assembly there is hardly a way to screw it up.
I think that you underestimate how much more metal is in the Q8, it has a higher heat capacity so it warms up (and cools down) more slowly.
Again as evidence, my stock SP36 did 6800-6420 lumens - about 1000 lumens higher than any stock Q8 I've tested -- main reason: XP-L2's. The Q8 XP-L's are V6 and I assume the SP36 XP-L2's are also V6, if so, the SP36 must be pulling more amps.
I was not able to detect a difference in lumens between my Q8 with 30Qs and SP36 with VTC6. Looks like buying VTC6 was a waste of money, 30Qs are just as good even for powerful flashlights.
I get consistently higher output #'s on VTC6's vs. 30Q's in many FET based lights. Not just 1 or 2, it's every light - factory FET based, or modded, I've tested - dozens. Whether you notice it, is something else. Comparing a Q8 and SP36 is different LED's, different tints, somewhat different beam patterns.
Not sure what "TA calibrated" means. I have one of the "original" PVC based measuring devices made by the brothers Rick and Rodney. Those #'s are my typical calibrated measurements I've been positing here on BLF for about 5 years or so. I re-calibrated it using the maukka calibration lights and figured the results are 12% lower than my previous calibrations based on manufacturer spec'd lights - 100's.
So just subtract 12% from my #'s and you got maukka ANSI calibration.
I made one from the clear plastic cap on a laundry detergent bottle. Sanded the inside to frost it and put white paper at the bottom (top?) to reflect light towards the table. Works pretty well at about 1,000 lumens.
I am a bit disappointed in sofirn, i bought an SP36 almost 2 weeks ago on their AE store and it showed as ‘in stock’
Next day i received a tracking number, but until today no result, so shot them a message, their reply was, sorry the item was not in stock, we will ship as soon as we have it on stock…
@kawiboy, Nice to read you got it open that easy! did you use that bended bodkin, or what tool is it?
Did it require much force? Did you need to heat up the light first? Did you need to push through the button hole? It’d be nice if there’s an easy way to get the driver out.
It was a while ago, but I believe I went thru the LED wire holes with a solder pick, poked the driver loose - no difficulties I recall, but I've done it this way many times on glued up drivers. Sometimes it needs light taps from a hammer, but the solder pick is not a very rigid tool - mine is a bit bent up from abuse over the years. In general, I always keep the solder pick to the outer edge of the driver to minimize potential damage. 99% of the time there's no damage, most of the time gentle force is enough.
I think you are referring to the SP33 now, since you cant really remove the reflector of the SP36 without damaging it, since it is screwed from below. THIS was how you opened the SP36
Nope not really much force was needed, nor did I use any heat….
I removed the switch and pressed directly down as close to the driver ring as I could get, if you look between L- and L+ you can see the copper shinning thru the masking where the pick made contact. It didn’t take what I would call excessive force, even though I was pumped up for a fight!
First I pressed slow and steady I heard a faint pop, then during the second press it popped out cleanly. Lucky the driver wasn’t glued and then press fit, witnessed by the glue around the outside edge on the driver board, so initially the driver had to be kind of sloppy/loose to the diameter of the driver pocket. The glue couldn’t penetrate the ano and the single point of pressure peeled the two surfaces away from each other.
I thought about taking one of my long punches and striking it with my small brass hammer, but the angle was to drastic and didn’t want to take a chance of knocking something off the board, ripping the contacts off the board along with what ever SMD got ripped off and launched…I thought it thru and decided, it wasn’t an option after all.
You can see around the drivers face what glue was left behind on the driver shelf, it flicked off with out much resistance also. I have had better battles with pressed in drivers then what this one gave me really, I was totally surprised, shocked, ecstatic and relieved at how easy it was to be honest.
