i will get XHP50.2 3V J4-3C and J4-3A soon
each bin 500pcs
no ,i dont have this kind of driver
what LED do you want to be installed in S11?
Good suggestion,i’m ready to name it “S21A”
Convoylover:S2+ 21700 is the most interesting to me! Will it be available in various anodization colors like the normal S2+?
Another important question: will I be able to use the same optics (both reflector and TIR) with S2+ 21700, which are suitable for S2+ 18650 currently?
a little large, but i think if you dont remove the glass lens ,
the TIR still can be installed
Something I’m noticing with the H1 is it only has one small groove that could accommodate a pocket clip, and only in a head-up configuration. I usually prefer my angle lights head-down in my pocket, and a larger groove tends to make the clip more secure.
When it comes time to revise the design, better support for pocket clips, in both head-up and head-down orientation might be worth looking at.
i thought head-down was useless, so i just add one groove.
Where do we use head-down? is there an example
This is for using a right-angle light as an everyday carry light in a pants pocket. Head-up usually results in a large amount of the light sticking out of the pocket, where head-down does not.
So if I bump into things (read: constantly) then I’m not scratching the lens
Simon Mao:i thought head-down was useless, so i just add one groove.
Where do we use head-down? is there an exampleThis is for using a right-angle light as an everyday carry light in a pants pocket. Head-up usually results in a large amount of the light sticking out of the pocket, where head-down does not.
i see ,thanks ,i didnt consider this ,i should update it in the next batch
Satan@103TFS:Hi Simon ,what about XHP50.2 6V and 3V in 5000K range ?
each bin 500pcs
What about XHP50.2 6V K2 5000k ?
I need H1!!! I want H1!!!
S11 up! Aaaaaand purchased
hello Mr Simon Mao, I see an interesting silver S2+ for 21700 size in your photo! Is this for sale yet?
No, it isn’t if it is not on his site. This is the 1st picture I’ve seen of it, the S21A
i really hope name change for the 21700 version, less confusion with the s2+ that already has a few models out.
i like the silver host tho, sexy.
XHP50.2 5000K (or 6500K) should be fine for me. Did I get it right that total number of S11 modes is four (0.1–3–30–100)?
Yeah, Simon confirmed on the previous page that he is going to rename it the S21A.
H1 available now on Gearbest. Aaand the price is
I can’t find it… Do you have a link?
