[♛ FreemeGB] Fireflies E07 7* Nichia/ SST20/ XP-L HI Emitters 21700 Flashlight Group Buy -【 New Copper+Titanium 】
616 posts / 0 new
SKV89
Last seen: 8 hours 58 min ago
efi5phd wrote:
I would like all copper for the best dissipation of heat. Thank you. Or aluminum and copper.
That’s what I used to think too but it’ll add significant weight for not much additional heat shedding. The majority of the heat shedding is done in the head so copper head makes good sense but body not that much. Also copper will sink heat so fast, it will make it uncomfortable for your hands to hold if the body is copper too. I’m not against full copper body but just copper head seems good enough.
808Hi
Last seen: 2 weeks 2 days ago
Interested in copper
808Hi
mihlit
SKV89: I don’t think that copper head would make a huge difference. It’s not about better, it about pretty Smile
SKV89
Actually it does make a huge difference in turbo runtime. I compared S2+ copper with S2+ aluminum using same pill, the copper can maintain the turbo much longer, maybe twice as long but it also takes much longer to cool back down. Copper also helps with heat shedding since heat transfers to the surface faster but the difference it makes is probably not too significant.
twisted raven
Last seen: 3 hours 26 min ago
Seems like the copper would cool down faster than the aluminum.
nokoff
nokoff's picture
it’s more conductive, not more emissive, but it’s going to do a better job of extending turbo with a thermal cutoff, it always does
Nokoff..still Made in China 山寨主義
BlueSwordM
BlueSwordM's picture
Last seen: 7 min 44 sec ago
It also has a much higher density.
Even though copper actually has a lower thermal mass per weight compared to aluminium, it’s so dense it actually eclipses aluminium in both thermal conductivity and mass.
twisted raven
I think heat conductivity works both ways, as it’s only one thing. It’s how fast the material transfers energy through it. The processes of heating and cooling down both involve energy transfer. But if we were talking two heatsinks of the exact same size, I could see the much heavier copper taking a little longer to fully cool down because it has much more mass to it, but that’s only if more energy was ran through it in the first place (ie 2 minutes of turbo vs 1 minute)
If we took copper and aluminum and allow both to absorb the heat from turbo for the same time, the higher thermal conductivity of copper means it should completely shed its heat faster than aluminum.
In that same manner though, if the copper were exposed to a level of heat that didn’t oversaturate it within seconds (turbo output), I would imagine it could allow the light to sustain a higher level of constant brightness than the aluminum heatsink.
Unloco
Unloco's picture
Last seen: 1 day 15 hours ago
Copper head + clear aluminium body for me, depending on final price.
noboneshotdog
I would be interested in aluminum w copper head too, but QC issues would have to be worked out.
I will wait and see before I pull the trigger on FF lights going forward.
Thier ain’t no bones in a hot dog. F. York
KawiBoy1428
KawiBoy1428's picture
Last seen: 9 hours 32 min ago
Same here. Would like to see PIC’s as proof also… a copper core pressed into an Aluminum finned head might have been better, it works really quite well in my 19 amp 4200lm 3v 50.2 IRA. But I sure like that Copper head!!!
Did a copper pill X6 3v 50.2 also..it’s quite Heavy…
KB1428 “Live Life WOT
mpak87
Last seen: 2 years 6 months ago
Depending on price, interested in clear aluminum + copper head, though I’d like to know the price breakdowns for full copper or TI body. 5000k XP-L HI with red secondaries if at all possible.
mortuus
mortuus's picture
Last seen: 9 hours 21 min ago
hm saw on Neals fb they discontinued nichia ?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Charga
Charga's picture
Interested for one clear aluminium body with copper head!
' Lumen est omen '
Hope is no option!
jaynick
Last seen: 2 weeks 6 days ago
Id buy a copper head+clear ano body for sure.
Ill be buying the copper+ti if not too expensive.
Firemedic
Firemedic's picture
Last seen: 2 years 9 months ago
I think the copper head would look better with the desert yellow. It would kinda match somewhat:)
g_damian
g_damian's picture
Last seen: 2 hours 16 min ago
Interested in copper one. If not available, cu+ti.
MichielSanders
MichielSanders's picture
Last seen: 3 months 3 days ago
interested in CU+TI
Olight: M3XS-UT, S Mini CU, R50 Pro LE, M2R, I3T Cu, S30R III, Marauder X6, X7R, X9R - BLF: Q8, A6, GT, GT mini - Emisar: D1s, D4Ti - Reylight: Tripple Dawn, Ti Lan
Nitecore: TM26GT, SRT9, EC11, T5s, P05Pink, LA10, HC33, HC70 - Fenix: TK75Vn FiatLux, TK76, CL05, CL09 -  Lumintop: Tool Ti, IYP365Ti - Astrolux: MF01 Lexel driver
Tally-ho
Tally-ho's picture
Last seen: 2 months 6 days ago
Interested in Cu head + Al body clear ano but depending on weight.
The Astrolux S43S is already on the heavy side for me so i’m not optimistic for the E07 copper head with its 10 mm shelf.
Tubercle
Last seen: 10 hours 40 min ago
Interested in both titanium and copper versions too!
DB Custom
DB Custom's picture
Last seen: 2 days 2 hours ago
The Ti/Cu E07 definitely needs to find it’s way into my hands!
Please make sure you have me down for this beauty!
CM2010
Last seen: 5 min 11 sec ago
Interested in titanium and copper.
ollywood
Last seen: 12 min ago
Cu+ Ti please…
timbo114
timbo114's picture
Last seen: 16 hours 29 min ago
I’m IN for the Ti/Copper
Pöbel
Pöbel's picture
Last seen: 2 days 9 hours ago
freeme wrote:
Good news, Jacky is back. He told me that Banggood will receive new batch of E07 within these few days. If you got have been cancelled previously, you might want to try reordering again next week.
fantastic news. I left my order with banggood active for a long time without too much hope that it would ship. It even had the apply for refund option active. Today I checked and it did indeed ship.
4000k XPL Hi sand colored Smile
electricjelly
electricjelly's picture
Last seen: 3 weeks 7 hours ago
Interested in Copper Titanium E07
Light
Light's picture
Last seen: 2 years 8 months ago
Interested in full copper limited edition. I’ve been emailing Jacky at fireflies to get some information. Very excited for this version.
-Max
DB Custom
DB Custom's picture
Full copper vs Ti/Cu….
The Titanium almost acts as a thermal blanket or shield to protect the cell from intense heat of the 4 emitters, the copper pill will absorb and radiate heat allowing the emitters to run efficiently but the Ti body/battery tube won’t readily absorb this heat, effectively keeping the cell as cool as possible while the light delivers optimum output.
Whereas, a full copper build will pull heat all the way to the tail, surrounding the cell in heat and possibly causing damage or a dangerous situation to the Li-ion cell inside. Yes, it will pull more heat from the emitters, but it pulls it to the dangerous cell within… not a good compromise in my book. And I am probably the biggest advocate for the use of copper on this forum…
As an aside, the Ti battery tube will remain much more comfortable in hand than a full copper build, which would get too hot too hold in short order.
mihlit
but… but… it’s about looks, I want full copper too Smile Same as I’d like to have full titanium or at least titanium+clear ano head.
jojosupir
jojosupir's picture
Last seen: 1 year 4 months ago
Would love to have a glimps of E07 Cu + Ti edition before deciding purchacing one.This would be a great splurging out a flashlight.
