1- is the $99 usd price a pre-order/early order price only?
2- if so, how long will you be running the $99 price for?
3- what will the regular price be once the $99 price changes?
I needs one but this is also new summer tires month…
If I was to order one it would be the khaki sand version. Not because I especially like the colour but more because black is too ubiquitous and having a different colour makes it feel more special and unique.
I have this message “Things don’t appear to be working at the moment. Please try again later. ” while redirecting to PP page .In other shops everything is OK.
Question for all regarding driver efficiency between the M43 and the D18.
Low VF leds excess voltage will burn off as heat in the D18 when running on 7135’s.
M43 will be more efficient in terms of how it takes advantage of the low Vf LEDs due to the boost driver.
Do you think the extra 6 LED’s in the D18 will offset the efficiency loss compared to the Boost driver of the Meteor?
Of cause!
The flashlight is claimed as working only with button tops and the batteries are sold together with the flashlight. So they must be button tops.
I think you can use each flat tops where the top is higher than the heatshrink-tube. That schould be ok with all flat top, except with samsung batteries, from my experimence.
Hank seems open to producing a 3x18350 tube if there is enough interest here. But since he just asked us about this a week ago, I suspect 18350 tubes, if they are produced, won’t be available for some time.
