A few more notes.
You can go from Eco mode to Turbo.
Double click from Turbo activates dual frequency Strobe.
From Strobe, a dbl clk goes back to Turbo. A single click goes back to last used mode.
Features:
[1] By default the MT09R is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 predefined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Package included:
1 x Haikelite MT09R XHP70.2 3 x LEDs 25000LM LED Flashlight
1 x Screw
1 x O-ring
1 x Lanyard
BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
Brand:
BLF
Model:
Q8
Emitter Type:
XP-L HD V6 3D
Light temperature:
4750K-5000K
Light color:
Neutral White
Mode:
Smooth ramping or mode set operation
Material:
Aerospace grade aluminum alloy construction
Total Emitters:
4x
Battery Configurations:
4 x 18650 or unprotected button top (not included)
Working Voltage:
3-4.2v
Switch Type:
Electronic switch
Switch Location:
Body side of the flashlight
Peak Beam Intensity:
30000cd
Impact Resistant
1.2meters
Max Output:
5000+ lumens
Range:
450+ meters (max)
Lens:
High transmittance glass
Reflector:
Aluminum alloy mirror reflective cup
Waterproof:
IPX-8 waterproof
Color:
Black
Weight:
400g without battery
Size:
132mm x 59mm x 50mm(length x head x body diameter)
Features:
⢠Compact and lightweight 4500 Lumens flashlight
⢠Utilizes four XP-L LEDs
⢠Uses four 18650 batteries for maximum runtime up to 1500hours
⢠Features advanced temperature regulation (ATR) technology
⢠Integrated power indicator in side switch indicates remaining battery power
⢠Flashlight can blink out voltage with 0.1V accuracy
⢠Intelligent memory function for brightness levels
⢠Direct access to ultralow and turbo outputs
⢠High transmittance glass
⢠Stainless steel bezel ring protects core components from damage
⢠Constructed from aerospace grade aluminum alloy
⢠HAIII military grade hard-anodized
⢠Waterproof in accordance with IPX-8
⢠Tail stand capability
Mode,Lumens and runtime:
Mode Groups:
Runtime and Lumens (manufacturer tested,it will be a little bit different from the real data )
Group1:
Moon 2LM/1500h
Turbo
5000LM/40min
Group2:
Moon 2LM/1500h
Low 160LM/33h
Turbo
5000LM/40min
Group3:
Moon 2LM/1500h
Low 70LM/66h
Mid 1250LM/8h
Turbo
5000LM/40min
Group4:
Moon 2LM/1500h
Ultralow 10LM/150h
Low 160LM/33h
Mid 1500LM/6h
Turbo
5000LM40min
Group5:
Moon 2LM/1500h
Ultralow 10LM/150h
Low1 70LM/66h
Low2 160LM/33h
Mid 1500LM/6h
Turbo
5000LM/40min
Group6:
Moon 2LM/1500h
Ultralow 5LM/150h
Low 70LM/33h
Mid1 240LM/17h
Mid2 1100LM/10h
High 2500LM/3h
Turbo
5000LM/40min
Group7:
Moon 2LM/1500h
Ultralow1 10LM/400h
Ultralow2 35LM/140h
Ultralow3 95LM/54h
Low1 160LM/33h
Mid 1350LM/8h
High 2500LM/3h
Turbo 5000LM40min
Group8:
Moon 2LM/1500h
Low 160LM/33h
Mid 750LM/17h
High
2100LM/5h
Group9:
Moon 2LM/1500h
Ultralow 10LM/150h
Mid 520LM/20h
Turbo
5000LM/40min
Group10:
Moon 2LM/1500h
Ultralow 10LM/150h
Mid 1500LM/6h
Turbo
5000LM/40min
Group11:
Moon 2LM/1500h
Low 160LM/33h
Mid 1350LM/8h
Turbo
5000LM/40min
Group12:
Moon 2LM/1500h
Ultralow 5LM/600h
Low 150LM/33h
Mid 1700LM/5.5h
Turbo
5000LM/40min
Package included:
1 x BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
2 x Flashlight Body Tube O-ring
1 x Flashlight Head Lens O-ring
1 x Switch cover
1 x English Manual
Note:
Before ordering please make sure that you know how to operate the flashlight.
