Need some repair work on a broken BLF A6
The ability to do basic repairs is important if you want great tints and totally wonderful lights .
The forum proves that waiting around for vendors or manufacturers to put great tints in a light just isn't ever going to happen .IMHO the two NW tints used in the BLF A6 both suck .People like them , but my dog also likes to eat cat ****.
BLF has proved that you don't need to spend a ton to get some pretty sweet lights .A nicely designed driver by members here and a great emitter make things about as good as it gets . Whatever you spend on a soldering iron solder /flux and emitters pales in comparison to what you'd have to spend by buying multiple lights and expecting to finally discover a good or interesting tint, high cri light . Yes you can pay people to do mods for you but that gets silly when just shipping alone eclipses the cost of parts needed to fix or upgrade a light .Worst case scenario you become a flashlight modder fanboy and start endlessly promoting them and praising them only because you stupidly spent too much for a light .It happens all the time .people have to justify why they threw down big money so suddenly Mr. modder is a hero . I think if it's not some super custom designed Titanium light like a macgizmo , hanko or kuku than tossing too much money at a light is a sad admission of failure . It's like not being able to change your own oil or make a grilled cheese sandwich.
An emitter swap is clearly the fastest way to see real change in a light... and happens with just soldering two wires and some heat sink paste.
I can change oil but i choose not to any more. My cooking skills are actually pretty good and constantly improving.
Get a Sous Vide machine and you’ll make perfect steaks
I will fix it if you want to buy the emmiter of your choice and pay shipping back and forth. How do you know it’s the emmiter? May have said already. Only read the OP.
Thanks Hondarider, but these other patient folks have convinced me I have nothing to lose and much satisfaction to be gained by performing what they all claim is an easy thing to do. I'm going to give it a go.
When it finally arrived it worked. I disassembled and reassembled it several times examining every little thing I could think of to look at. After lubing the O-ring and threads I reassembled it yet again and it no longer functioned. I've since learned that this LED should have a dome over it. This one does not. I honestly can't say if the dome was present or not when I started playing examining the light.
Is the battery tube around the correct way?
Oh forgot about this :confused:
Yeh, reverse the direction of the battery tube before attempting the fix. Sometimes it works like a miracle.
I read some posts about that problem. On my sample the MCPCB sits in the head end of the battery tube and is almost flush with the end of the tube. The only way I could have the tube reversed is if I screwed the tail cap onto the MCPCB.
Is the led not lighting up? If so are you sure it’s the problem and not the switch? Did you try a different battery? From reading your posts it doesn’t seem as if you’ve really narrowed down the issue with the light. If it was me I would try a different battery and if that doesn’t make a difference then determine if the switch is the problem or not (easily done with scrap wire). Also did you check that the retaining rings are all nice and tight?
Edited to say that I forgot to mention that you can also remove the tube from the head and directly apply power to it to see if the led lights up or not.
I tried several different batteries, protected and not, buttoned and flat. I tested each battery in another light.
The retaining ring in the tailcap is solid. I don't have a tool which will extend the length of the battery tube to reach the forward retaining ring. There is no play at the MCPCB from the forward side of the battery tube.
I did the wire scrap across the negative battery post and the body. No joy, no LED light.. I didn't think of applying power directly to the LED connections. I'll try that tomorrow. I assume polarity matters.
The red is positive and black negative on the board that the led is mounted on. You can use either a battery or 3.5ish volt power supply to briefly touch the 2 soldered connections. If it lights then the led is good and since you already did the wire test then it’s probably a bad driver or a lose connection in it. Be careful because it’s possible to de-dome the emitter (although you said it already is, which seems odd to me). The de-dome issue was mentioned in the BLF A6 trouble shooting thread here
If you remove the head from the tube you can use a small head phillips screw driver, etc to push against one of the dimples in the retaining ring to see if it’s lose or not.
I think you missed a part.
Lights like the Convoy 2 ( + ) have three parts: the head, the tube and a tailpiece.
The A6 consists of four major parts:
- the bezel: here you find the lens, an O-ring, and the reflector,
- the “pill”: on one side you’ll find the PCB + led, and at the other side the driver + spring, and a retaining ring,
- the tube: a piece of aluminum pipe with threads and O-rings on both sides,
  • the tailpiece: with a PCB + spring + switch, a retaining ring, a washer and a rubber tailcap.
1/ MRsDNF has asked you to reverse just the tube. The manufacturer of the A6 does not use oversized pieces of metal. Sometimes two connecting parts just barely make contact, or barely not. Cleaning the rims of the tube and reversing it may help.
2/ Have you tried if the retaining rings on the driver and on the switch are properly fastened?
3/ You can test if the trouble is in the tailpiece by removing that part and short circuiting the (bare) backside rim of the tube with the underside of the battery with a pair of pliers or scissors.
BlueSwordM: Thank you for the shopping list.
SigShooter: No joy when power was applied directly to the LED connections. About removing the head from the tube; does it just push out the front of the light? I applied a little pressure with a pencil from the rear and nothing budged. I was reluctant to push too hard though.
RobertB: I'm very happy with my Weber thank you.
MRsDNF, BlueSwordM, Streamer & Henk4U2: Are you suggesting I remove the "pill" and reinstall it in what is currently the tail end of the battery tube? (Pls see my response to SigShooter above.) This is probably unnecessary, but without pictures it didn't really happen:
For reference, Image 1.
I found a pair of needle nose pliers which reach down to those two divets (one at about 11:00 o'clock, the other just visible at the bottom of the image.) I applied quite a bit of pressure in both directions and it didn't budge. Apply more torque? Counter-clockwise?
For reference, image 2.
For reference, image 3.
The LED wires are just visible on the left end (the head). On the other end (the tail) the distance from the o-ring to the end of the tube is visibly longer than the similar distance on the head end.
One more thing. If that retainer ring can actually be unscrewed, there are no interior threads at the tail end to mount it and the pill to. Is it a press fit?
Something doesn’t look right in the construction of your A6. Where did you get it from? Here is the Banggood page for the BLF A6. You can see some pictures of it taken apart. It is different than yours internally.
BLF A6 at Banggood
EDIT: Just now realized, you do have another section to take apart. That part with the driver in it is a separate piece from the battery tube and can be unscrewed from it.
It is pretty simple. Just wasn’t sure if you wanted to invest in soldering supplies. This is how it all starts. I have 5 soldering irons and a box full of wire, small plyer sets, fluxes, cleaners and etc. It keeps growing. Usually starts with a small job then you say ” I wish I had that tool” or ” Wish I had a flux pen ” and before you know it, you will have a box full of stuff. Good luck with the repair.
Wow! Thank you profusely DavidEF. That's going to make things much easier. I thought it was kind of a dumb way to build it, but I've never had an Astrolux light before and besides, I'm a Noob. Do I have to change my user name to Missing Tube Guy?
Yes, I'm embarrassed.
Regardless, turning the battery tube around did not produce any light at the LED. And yes, I put a battery in it.
Tell me about it. Anybody want to buy a Radial Arm Saw? Tablesaw? Bandsaw? Belt Sander? How about a Valkyrie? Leathers, helmets, heated suits and really good gloves? I have some golf clubs someplace.
I could go on.
Anyway, Thanks again to everybody for the advice. Your schoolin' me good.
Guilty as charged. I've definitely made this mistake!
I had a fairly nice light that I maimed, trying to get a pic of the emitters for a buyer.
I donated it to DB custom, as he has always been super helpful.
For him, to pop new emitters into it, for his own use, it was perfect.
Too cost prohibitive to ship back and forth AND pay for the 4x emitter job….
.02
