hi,…does this take only Protected 18350?.
I have a Keeppower Unprotected 1200mAh 18350 flat top
thanks.
thanks.
no
I have Keepower Unprotected 1200mAh and it works in my original RRT-01, so I suspect it will also work in the new RRT-01
otoh, my Keepower Unprotected 750mAh does not work (the button top is wider)
if you want the option to use Protected… the new model does
still no battery check, but now theres a strobe
I would buy your old one…
LOL
congrats
you already have the best TiRotary, and it did not cost $1000 (HDS)
See the video from Vinh (Skylumen) posted in the last pages!
I just got mine and can’t wait to get home and mod it with a Nichia 219b 4500 LED.
I noticed the LED already in it does not have a dome. Should I de-dome the Nichia as well?
No, do not dedome that LED. It has a small enough die and great beam for this type of EDC light.
This. It's got a good amount of throw and flood.
Thank you sir!
thanks. I have a flat white RRT 01 build on way, but on the look out for another RRT 01 to compliment it, but what to have as an LED?.
E21A?, Optosolis?, or even a triple?.
thanks
E21A if Clemence makes a retrofit “kit”, depending on the beam type he can achieve.
I would choose a single LH351D over a triple if you want floody.
yes I am on E21A too.
Single. Thanks.
I just got mine. Other than off and turbo, I don’t have detents on the ring, it’s just smooth.
My V11R does have a far better feel when turning the ring. Was there a post how to disassemble the light, so I can regrease the ring?
doesn’t sound like you’re thrilled?
Not really actually. The ring action doesn’t feel nice. It has some scratches out of the box and the clip is made out of tin foil.
Guess it needs some modding love, for now I like my V11R better.
After much looking and inquiry, I found one! A lovely TCR1! Amazed these aren’t discussed more often. I am not usually a big fan of titanium, but this light is sublime, IMO.
WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion]
My RRT-01 came in too, and since I’m not spoiled by owning a V11R, I love the control ring and how low the light can go! And it looks just as good in reality as on the pictures. The thin clip I see as useful, it is nice springy.
I soldered a brass button on top of a 1200mAh Keeppower 18350 so that will be its principal battery.
Now installing the (6x2mm) trits and contemplating which led it gets, maybe one that does not exist yet
I soldered a brass button on top of a 1200mAh Keeppower 18350 so that will be its principle battery.
Glad you like it. It’s probably just me guys :person_facepalming: . I’ll report back after I modded it.
Got mine. It’s decent. After I mod with a high cri LED or three, regrease the ring, swap clips and add trits, it will be great!
Seems like a lot of work but this UI is rare and nice.
Ok. Went to the shed to give it a go. Regreasing with thick grease improves the feel alot, bit still not like my V11R.
I can confirm that my light has no detents and is different than the lights showed earlier in the thread.
I put in a 3000k sst20 and I am starting to like it better. I’ll EDC it for a few days and will decide if it’s worth the expensive trits upgrade.
How did you open it?
