Opus BT C3100 Erratic Behavior - Fan Gone???
PERFECT user name for your fan,A FLUKE!!! LOL! And I am not talking about the DMM By Fluke!
Quieter.Yes. More powerful? Not a chance! The reason it is quieter is because of its inability to MOVE air as well[CFM]. The specs and difference in performance have proved it.
The reason mine is a little louder is because it has a much, much better ability to MOVE air[CFM] which keeps the charger cooler and operating better.
There is NO comparison b/w the fan you listed which is similar to the STOCK fan and my TOP TIER DELTA fan that I have been using for almost 2 years.
No more stoppages during discharge tests which gave inaccurate capacity readings and no more RESETS at the transition from discharge to charge. Believe me, read my thread, I did extensive testing to come to these conclusions!
Specs. for fans: DELTA: 25mm X 25mm X 10mm——————-ADDA:25mm X 25mm X 09mm. The only difference is 1mm in depth.
Stock[ADDA] fan- 5v/0.13a/0.65W,In terms of specs, basically the same fan as you posted.
Delta fan- 12V/0.12A/1.44W,MORE than Double the Watts to power the fan!
SPECS for delta fan. CFM [Air Volume] is the key,IT is superior to the stock fan and the replacement fan you posted. iirc their CFM is about half!
There are several factors. My DELTA FANS HAVE 5 blades,the stock fan and yours have 7 or 8 blades,quieter,and again,does not move air as well.
My fans,more expensive but well worth it. I got mine for FREE[2] from a dealer in California who was following my thread and wanted me to test his.This is another source.
I stand corrected.
Thanks for being honest.
I did not know any of this until my Opus gave me problems 2 years. Dr. Gauss and others helped me understand it and suggested the DELTA replacement fan and the LITE-ON Power supply. Between the Two it is like a brand new charger. :+1:
I got one of the gearbest ones, my Opus runs better and a lot quieter.
But I will get one of those you listed but shipping to UK is a ransom.
If it works well and you are not having problems with your STOCK power supply, you probably do not need to.
In this thread,a very comprehensive one, you will see how I and others had multiple problems with the STOCK power supply.
The meat of the discussion starts around page #4 post #120
A look with my DELTA fan installed. It is slightly bigger[1mm] in Depth so it protrudes a bit.No issues, been working like a mule for 2 years! :+1:
Set up w/ my Lite-On SMPS
CLOSE UP
I’ve got a BT3400 v. 2.2 and its OEM fan has been quiet, but I bought two of the Delta fans off of Ebay just to have as spares, as Wolf has suggested.
I also bought the LiteOn 5.5A 12v power brick and while I don’t use it regularly, it was fairly cheap to get ($12 shipped?) My inner hole on the barrel connector is slightly over sized, so if I jiggle it when the charger is running, it’ll disconnect, but I just don’t move the charger once things are charging.
Chris
The barrel connectors are slightly different. I got adapters for a few dollars and they are snug.
I like the 90 degree one. That is the one I have been using since spring of 2017 when I made fan/SMPS changes. :+1:
Thanks for the advice, as always. Do you recall the specific size(s)?
Thanks, Chris
I will have to search through the that old thread……….I will find it either b/4 I leave for trail or when I get back!
VERY IMPORTANT NOT TO REVERSE THESE NUMBERS.
It needs to be 5.5mm X 2.5mm MALE TO 5.5mm X 2.1mm FEMALE
here is thread where we talk about the adapters and show a few pics.
If all else fails I have a few extra ones!
Thanks Wolf. I’ll take a look, but it’s more of a minor nit. My 2A wall wart works fine, although my first one from Rdana crapped out on me @ 4x1000mA. charging.
Chris
I’m still using my original fan ,it got noisy once and I just gave the housing next to the fan a few flicks & it’s never done it again.
I have opened my opus a couple of times & while it was open I took the fan out & took all stickers off it & sprayed it including the windings with spray on 3 in 1 oil.
Hey wolfdog you sent me link in the other thread for the adaptors from alixpress, they fit good & are right angle.
My fan also started making noises last year but a squirt of Tri-flow after I took it out fixed that right up :slight_smile:
Is triflow an oil?
Glad to hear that. I did not have time to search the thread because I was on my way to the trail. I am curious,where is the link to those?
I thought I got them all on Ebay.
Where is OP at?!! He started the thread and has not been seen since!! :laughing:
@Chris DISREGARD THAT link I posted below for the Barrel connectors! The listing ended and the ones they posted are WRONG!!
https://www.ebay.com/itm/7-9-5-5mm-DC-Male-to-5-5-2-1mm-DC-Female-Power-Plug-fo-Lenovo-IBM-Laptop-Adapter-/253600326860?
oid=142340377628
I have Two spares I can send you if you want. send me PM w/ your address
Yes. I use the spray-on can but you can get it in squeeze bottles, etc. To be honest I haven’t notice much difference in light oils and I think there’s a lot of marketing hype regarding them.
These are the ones I got a while back , they were just over £3 but now they’re only £1
With these I can pick the opus up & move it around with no loss of connection.
Look what I found on AliExpress
http://s.aliexpress.com/IFfMVbqa
