And Simon.
For the lots of Plain torch owners out here.
A C8+ with single or triple LED. 26650 cell.
and basic ON/Ramp. Turbo. OFF. SIDE switch only.
A L2 Convoy the same would be nice tooo.
Rear switches are soo awkward I find.
Unless a person has small hands. the 26650 tube
is soo much more comfortable to hold.
Oww, I thought you mentioned that reflector and pill were the same as the S2, so a lot could be interchanged.
Are you planning to produce 20mm drivers with 7135*x single/5mode and Biscotti?
Simon, that sounds nice, that you change the UI… Can you tell about the LEDs you will offer in the new batch (Hi CRI SST20 3-4000k or others… SAMSUNG LH351D 4000K 90CRI LED also fine:-))??
Jens
and thank you again for your fast answers in this forum!! :+1:
Simon, for the USB charging lights, how difficult would it be to switch to a Type C port?
Most phones (not counting Apple and their Lightning port) have been using Type C since 2016. That means people are more likely to have Type C cables laying around than Micro. Not to mention Type C is just pbjectely better in every way.
Personally, I’m trying to phase out Micro USB and actively avoiding buying new products that have it. Even if it causes a small price increase, I’d gladly pay that to not deal with Micro USB charging cables.
I noticed some interesting options for the XHP50.2 emitters listed in the Convoy store. The description says “Ra(H4-3A)=90 other Ra= 70”.
First of all, an XHP50.2 in a rosy tint bin with 90 CRI? Given the reputation of current generation Cree emitters, I’ll believe it when maukka’s photospectrometer sees it, but that could be pretty amazing. Of course, it will still likely need heavy texturing or some diffusion for a nice looking beam.
And then there are 40G and 30G lumped in with those “others” that have Ra=70. This is not listed in the datasheet; might these actually be Ra=80?
