Amen to NO green tint.
I’m in too. Also, headlamp with Anduril pls.
Shaving?
Interested
Amen to WEAK green tint.
sofirn is going to make another version SP36 Pro with 4* XHP50.2 10K lumens and sofirn designed driver.
Put that on Amazon and I’ll buy one!
Interested.
interested!
Interested
Interested if the driver is not glued
How close are you to release? Any news?
Barry0892:sofirn is going to make another version SP36 Pro with 4* XHP50.2 10K lumens and sofirn designed driver.
Wow. I’d be in for that one for sure!
it will be April since the reflector, driver and other parts are different, it takes more time than the SP36 Anduril version.
Interested
Sorry I have to say plan changed. the first 10000 lumen light will not SP36 Pro but Q8 Pro, because SP36’s head is not big enough for bigger leds or more leds.
let’s wait and see.
Oh, the SP36 Anduril version goes as planned.
let’s wait and see.
Q8 Pro 4*XHP50 is also good, we are looking forward to it.
Barry, will you be using 3 Volt XHP50.2 or 6 Volt XHP50.2?
very interested!
around 5000k
maybe slight OP reflector for nice homogeneously beam
SS Bezel like Q8
maybe SS tailcap…(like FF Rot66)
PS; better tailstand, my SP36 stand only on the inner “raised ring”, the outer “ring” is a bit to short, so the tailstand is not optimal
3 Volt XHP50.2 is limited, sofirn won’t see a model to be discontinued too soon
LED for Q8 pro is not confirmed yet, XHP series are more powerful but higher volt, sst40 is good not never tries before by sofirn
The SST-40 will not give enough more output compared to the old Q8 to call it a “pro” version, maybe 6000 lumen if low conductive springs are used.
XHP50.2 3V however will give an instant 10,000 lumen or more. It is a pity that they are limited, maybe ask Cree directly?
