Higher lumens, further throw, better heat dissapation, better UI, cheaper price.
Here is the defunct Kronos K70 cutaway.
No holsters.
No holsters.
And what about the smo reflector?
It produced some artifacts so they went with a light texture to make it look nicer.
There might be a true SMO reflector later.
In tests, the SMO measured 31 meters more throw. So it’s a small sacrifice for a nicer looking beam.
As I look at this reflector, I have the impression that it has “thick” textures. I hope that beam will look much better.
This is thick texture. The Kronos K70.
holsters only for Q8/SP36/C8F/SP33/SP31series/SP32series for now. I guess sofirn can get one for SP70 in the fu…
Wait, SP70 is supposed to come with a sling. Isn’t it convenient enough?
uh, sorry guys in Germany, I need to be clear. Same price was meant to be the same price number, actually it’s USD$50 in aliexpress and amazon US and EUR€50 in amazon DE
You know the reason why right?
You are writing about this holsters: 0.46€ 91% OFF|Gute qualität taschenlampe holster taschenlampe schützen fall für sofirn taschenlampe|Tragbare Beleuchtung Zubehör| - AliExpress , right?
Can we get a special BLF discount?
will u sell this light on banggood ?
Quick question, just so I understand this correctly. If I order an SP70 and put my BLF user name in the comments I will get the SP70 BLF version? Or just the muggle version?
As said above, there is no BLF version yet, even what the specifications are has to be finally established,
The $50 price is just great. Time to procastrinate on whether I can afford it or not….
I’ll make myself afford it But will wait for the BLF edition. MORE AMPS
Sofirn, what about SP70 Pro ?
Either way this is still a BLF edition for us because our input made it. At the very best another BLF edition will add a SMO reflector and a retaining ring if they want to pursue that. Nothing else will change maybe in the future we will see a multi emitter XHP50/70 light from Sofirn using this design.
Sofirn can you make some SP70 that are not glued? So we can access the LED and driver easier?
Amps should be the same.
That might come later if the SP70 sells well.
There’s nothing making the LED hard to get to.
Yep, i am eager for the final BLF version as well
It’s about time, i can still remember the discussion about the design last summer when i was on holiday (and my wife was complaining about the fact that i was more busy with BLF on my phone then our holiday)
it feels like ages
I signed up for the original K70 w/SMO. I saw what difference it made on the L6, well published by VOB's vid on the L6 mod. Maybe this OP is milder, which is what's being said.
SMO, diced/sliced XHP70.2 - that's the direction I'd go. The SMO we need from Sofirn, but the dicing/slicing we need to do.
