[Review] YLP Panda 2M CRI (2xLH351D, 1x18650, dedicated headlamp)
12 posts / 0 new
bmengineer
bmengineer's picture
Last seen: 1 month 2 days ago
This review was originally posted on my site - read it there for the best experience.
The Product
The light I have today is the YLP Panda 2M CRI. This is a dedicated 18650 headlamp with dual emitters, in this case the high CRI Samsung LH351D. It is controlled with two buttons on the top, and uses two optics.
It's worth noting that YLP also sells a number of variations of this headlamp - the Panda 2M is the same headlamp with the less desirable XP-G3 LEDs. If you're picking between the two, I would highly recommend the high CRI option.
Spoiler
Up until recently, high CRI headlamps have been hard to find. There's been a few very expensive Zebralights, and some smaller options from Nitecore. There's also been a few headlamps with a high CRI secondary light - but really no affordable options that use high CRI for the main, powerful LEDs. Thankfully, that's finally changing!
This headlamp is great. The UI is intuitive and isn't lacking any major features, it's comfortable to wear, and the light it puts out is gorgeous. The 'headlamp-y' form factor should also appeal to people new to 18650 lights, and it will be a big step up from the mass market options.
Physical Dimensions
The light measures 111.5 mm wide, 22.8 mm thick, and 25.3 mm from front to back. The headlamp itself weighs 63 grams. Adding the headband brings that to 101 g, and adding in the flat-top 18650 below gives a 'trail weight' of 146 g.
Here it is pictured next to an 18650, Skilhunt H03 RCArmytek Elf C2, and Convoy S2+. Placing the optics next to the cell means it can easily be the shortest of the bunch, though it is a bit wider.
Build
The body of this light is constructed of anodized aluminum in a great gunmetal grey color. Machining and anodizing are good, though there are some small rough patches in the fins.
From the top of the light you can see the two switches, the fins, and the caps on either end of the cell tube.
The fins themselves are a bit 'sharp'. They won't cut you or anything, but they could have used a bit of finishing on the edge if I'm being totally honest. Since this light is designed as a headlamp, they likely won't ever touch anything other than their silicone holder, so this really shouldn't be an issue - but I felt it was worth mentioning.
The bottom of the light is a mirror of the top, minus the two switches.
Around the front, a plastic cover is held on with 4 Torx screws, and keeps the two TIR optics secure. The plastic cover protects the lenses themselves, and the manufacturer includes a spare in case it gets too scuffed.
The cap at the right end of the body is not readily removable, and houses the magnet.
Around the opposite side is the cap for battery replacement. Detailing around the cap makes it easy to grip for cell changes. The cap is etched with a "HI CRI" label, which is the only marking on the entire light.
Unscrewing this cap reveals the thick construction of the body tube. The threads here anodized, which means the light can be physically locked out from accidental activation by slightly loosening the cap. There's a sticker inside indicating the polarity of the cell, which gets inserted positive end first. The contacts with the cell at both ends are springs.
What's Included
The light ships in a snazzy black box that seems to be customary for YLP, as their Sherp S15 had similar packaging. The box closes with a magnetic flap on the front, and even features the product name in foil print. Inside, you'll find:
  • Panda 2M CRI with the headband
  • Spare o-ring
  • Spare lens cover and gasket
  • Paperwork
Ergonomics and Retention
This light probably isn't designed to be used without the headband, which will be the main way to keep it where you want it. The straps come assembled, which is welcome after struggling with the options from Armytek and Skilhunt. The elastic webbing used feels a bit less premium than some others, but it is comfortable and stays in place. The holder for the light is made of an awesome orange silicone. It's a bit stiff to adjust the angle of the lamp, but it's easily doable with one hand.
My one complaint is the top strap, which is far too long. Even with my giant head, I had it tightened almost all the way. This will be less of an issue if it's used with a hat or helmet. The straps do not have any reflective or grippy features.
The light also has a magnet in the 'tail', or the right hand side of the headlamp as worn. This is useful for hands-free use, even with the headband still attached. The magnet does not seem to be readily removable, which I know some compass-users will object to. it's plenty strong enough to hold the headlamp in any orientation.
Modes and Interface
The user manual does a great job of going over the features of the UI, so as usual I'll go through the basics of using the functions I used most.
  • From off, the orange button is momentary red.
  • From off, press the white button to turn on the light.
    • Subsequent presses will cycle up through the modes.
  • From off, long press the white button to turn on the light in moonlight mode.
  • From on, hold the orange button for momentary turbo.
  • From on, hold the white button to cycle through the modes.
  • From off, double tap the orange button to blink out charge level with the red LED (1-5 blinks)
This UI gets all the main points right. Something it adds that I've come to love is the ability to access turbo as a momentary mode from on. This is great for those 'what's over there?' moments, and avoids having to navigate back to the mode you were previously in.
The manual also points to the web version, which has additional configuration available.
  • Mode memory can be disabled or enabled
  • Output levels for low, medium, and high can be selected between two options. There are 5 available output levels for moonlight.
  • The red LED can be activated as a locator beacon.
  • Turbo mode can be set to use a timer, instead of being momentary.
  • Smooth transitions can be enabled when toggling modes.
The only feature missing from this UI that I can think of is the ability to use red as a constant mode. That's not a feature I look for myself, as I find dim white light to be equal or better in all aspects, but I know some desire that capability.
Light Quality and Beam
This is the real selling point of this headlamp. The light uses two Samsung LH351D emitters, both behind TIR optics. Maukka did extensive testing of this light (linked below), and his lab equipment confirms what my eyes see - it looks great. The high quality light makes it very easy to tell the difference between similar colors that tend to get washed out on a forest floor. Enthusiasts already know how great high CRI lights are, and this is no exception.
That's the beam compared to a 3500K E21A in a JetBeam JET-μ The beam is quite floody, but the turbo boost is more than enough for most hiking needs.
Power and Runtime
The light takes a single 18650 cell. Everything from a flat top 30Q to a protected Nitecore button-top cell measuring 69.7 mm worked without issue.
Standby current was measured at an astoundingly low 0.04 μA. A reading this low means the standby drain will not have any discernible impact on the cell life.
Runtime was tested using a Samsung 30Q. Both tests were left to run until the light shut off, at which point cell voltage was measured at 2.8 V (high runtime) and 2.9 V (medium) after settling.
On both high and medium, the output was quite stable without any drastic stepdowns. On high the light lasted 2 hours and 43 minutes, and on medium it lasted 9 hours and 20 minutes. Both these runtimes are just slightly below the manufacturers numbers, which makes sense given that they were tested with a 3000 mAh cell. A cell around 3400 mAh should have no issues reaching the stated times. It's worth noting that the highest constant mode still gets close to 3 hours of stable light, which is huge. The medium mode lasting 10 hours is an excellent length for longer hikes, and will also easily last through an 8 hour work day.
Summary
Pros:
  • High CRI 18650 headlamp with a great beam
  • Output levels are well designed for extended use
  • UI is intuitive and has all the functions desired, plus added advanced options - and I'll give bonus points to any good UI with momentary turbo
  • Magnet on the tail for off the head use
Cons:
  • Water resistance is not designed for submersion
  • Headband top strap will be too long for some users
  • Magnet is not removable
Notes and Links
This product was provided by the manufacturer free of charge, in exchange for this review. I was not paid to write this review, and have tried to be as unbiased as possible.
Manufacturer's product page (the only place i could find to purchase this light)
Maukka's review with detailed measurements of light quality
Find all my reviews of flashlights and more gear at www.bmengineer.com
saypat
saypat's picture
Last seen: 1 day 6 hours ago
I enjoyed the review as I am interested in this offering … but nowhere in the review did I see any info on lumen output, strange? I know we can get that from the product website however.
Doesn’t this light also have a special, configurable UI? Ok, I’ll go away.
bmengineer
I don’t always remember to talk about output, but I also don’t usually think it’s what’s important. For 90% of the 18650 lights on the market, the answer is “plenty”. But if you’re wondering, output on the stock levels is:
3, 35, 120, 400, 700 (turbo)
will34
will34's picture
Last seen: 6 hours 36 min ago
As someone who isn’t a tint snob and don’t pay much attention to Maukka’s tint and CRI charts, this review was a lot easier to digest and read through.
However I found that the turbo output and runtime information is missing in this review, and after some research I found it is 700 lumens for 20 seconds and high mode is 400 lumens for 3 hours. Whether that is plenty or not can be indefinitely discussed, most headlamps claim 1,000+ lumens of output but will drop to sub-600lm after a couple minutes, which I guess it’s not a whole lot more compared to this YLP in high mode.
For 35 bucks I think it is well worth the price, everything seems well thought out.
bmengineer
Thanks,I appreciate the feedback. I make a point of noting the levels next time. I didn’t do a turbo test because it’s momentary only on this light.
As for the output being modest, I think that’s really a feature on a headlamp. If I’m hiking for a week, the last thing I want to do is accidently burn through a cell in a few hours. If you need the highest output headlamp then I agree, this certainly isn’t it!
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 16 hours ago
@bmengineer, do you see any PWM on the moonlight modes?
Would like to know, thank you.
bmengineer
BlueSwordM wrote:
@bmengineer, do you see any PWM on the moonlight modes? Would like to know, thank you.
I only tested the stock modes and didn’t notice any at all, but I know maukka reported some. Shit h level was that in? I’ll check if it’s visible to the eye on my sample.
Bardo219
Last seen: 5 days 10 hours ago
Thank you for this review, I purchased the light a few weeks ago because of your testing.
I primarily use headlamps for caving and it is awesome to have more High CRI options in stock headlamps. It took about 10 days to arrive in KY from Russia, which I thought was very reasonable.
I’m a little concerned about the water resistance. I don’t plan on submerging it, but gotta move through some deep water when caving.
Overall I am very pleased!
Hoosh
Hoosh's picture
Last seen: 8 hours 27 min ago
I, too, purchased this headlamp because of this review. I received it today, 12 days after I ordered (which, honestly, shocked the heck out of me).
As a quick once or twice over…
1. The output, in terms of temp and CRI, is no less than spectacular. While I haven’t yet had it outside at night, the output in a dark room is perfect.
2. It’s super easy to get to the hidden programming modes. I changed the turbo to a latching time of 20 seconds and turned the smooth transitions to ON.
3. There is a small crack on the bottom of the plastic covering. Not sure if this will affect the IPX6 rating or not, but said rating was one of my only apprehensions about purchasing this headlamp. I know there is an extra plastic face included, but I feel like I shouldn’t have to “lose” one right from the start.
4. The fit and finish – excepting for the small crack mentioned above – is excellent. The screw side with the magnet must be glued on, which makes the magnet probably unremovable. My sample has nothing like what I would term “sharp edges.” The ridges around the back of the light aren’t “smooth,” but they aren’t “sharp” either.
5. I’m using a green NCR18650 protected battery in it. The fit is spot on.
Edited to add:
6. The red LED is so dim, it is almost useless unless you have whatever you’re looking at sitting right on your nose.
Given what I’ve seen so far with this light, if YLP would put these emitters into the 3.0 or the 3R, I would be an instant purchaser!
LightObsession
Last seen: 6 days 15 hours ago
This looks like a very nice headlamp.
Thanks for the review.
bmengineer
Glad everyone is so happy with theirs. Hoosh, it might be worth reaching out and asking for a few spares. And Bardo, I know the feeling – I’ve had to duck through a few rivers while caving too. I keep saying they should make a Panda 3 CRI, but even a “2.5” with the 2M driver and LEDs in the 3 body with better water resistance would be sick.
This is what I reach for for hikes and camping, but for caving the Armytek might still take the cake. Tough call.
Boro
Last seen: 45 min 43 sec ago
After using this for a while I’m not sure any headlamp checks as many boxes with the quality of this warm tint and beam @ BLF price point.
