I put the Q8 in my cart last night @ 40.59; today the cart price shows 41.99, same as product page.
Your listing on this thread still shows 40.59- someone needs to correct.
I’m unable to order bare batteries from Sofirn (no shipping method for bare batteries), so I ordered the SP33 with 26650 “bundle kit” instead at 2 different occasions to get hold of the Sofirn 26650 battery.
I notice that the 2 26650s have similar wrapping, but have slight difference physically. I wonder if one of them might be the so-called “high-drain” type.
I have yet to do a capacity test of the 2 batteries. But using YR1030 resistance tester. The more protruded 26650 (has smaller vent-holes, bottom is not completely flat) measured 41.7mOhms (AC IR) at 3.90v whereas the flatter 26650 (completely flat bottom) measures AC IR of 13.7mOhms at 3.90v.
One weighs 92.5grams while the other weighs 93.0grams (basically very similar weight, might even just be sample variance)
I suppose the 13.7mOhms version is the high-drain type?
I doubt it. The HD batteries have a button top added on and have not started shipping yet. They are also rated at 5000mah.
Do you have a clamp style ammeter to measure them in a FET style light?
As far as I know, Sofirn uses different generic batteries in 26650. Some measure closer to 5500mah and are labeled as such. Others measure closer to 5000mah and are labeled as such.
Sofirn SP70 with 4700-5300K color temperature, Sofirn SC31B with 4000K color temperature, add to your cart and enjoy the 11.11 deals amazing price , do not forget get coupons before order.
