And I think it should be clarified with the two high cri options (without getting into specifics of duv) that their color is not as well-described as green as it would be if they were a cooler temperature, regardless of whether you say lemongrass or just say “yellowish/greenish color”. To me, the sst20 comes across more yellow than green, as I have probably mentioned.
Thanks TK!
8000 posts :partying_face:
At last, a good laugh from this thread! Thanks caramba, any opportunity to use that old meme is a good one!
I heard that the light will get done quicker once the thread reaches 10k posts, I wonder if there’s any truth to that?
Same Vf, same amps, but SST-20 makes fewer lumens… so it should also make more heat.
Uh, that would mean power is the same for both if the VF and current is the same?
I think heat should be based on power consumption.
All in all, the XP-L HI has the highest VF, meaning it emits less heat.
We then have the SST-20 65CRI which has slightly lower VF, consuming a bit more power, but not really enough to be significant.
Not available here, but would be nice for max throw.
Then, we have the SST-20 95CRI and LH351D 90CRI have the same lowest VF, consuming the most power and emitting the highest amount of heat.
If we’re listing the worst thing about each LED, it seems like performing far worse on a metric some people value highly might be worth a mention.
The power consumed produces two things; light and heat.
If one produces more light than the other then the one with less light output should be producing more heat, if the voltsage and amps are the same.
If it was possible to build a 100% efficient led all the power consumed would go into light output and there would be no heat.
Huh, I completely forgot about that.
Thanks MtnDon.
:+1: :beer:
Thank You TK! That's very useful for me.
slmjim
It’s not low CRI; it’s just average CRI. Since you think it’s worth mentioning though, I added it.
I really hope they can get the LH351D!
The Super floody beam is much more usefull to me. Can not wait to get my hands on it. Perfect UI, high CRI, E-switch, super floody and very compact.
If it works without problems it will be hard for any other light to beat it as my new EDC.
Thanks to all that spend their time and work to make it possible!
+2 please
lol only lurking… My wallet is not a fan of my new life decision
yeah me too, but it seems that for now it will be not possible, maybe later on i dont know :frowning:
Probably asked before, but I cant find it. How difficult it will be to flash modified firmware to FW3A? Can it be done without disassembling and without soldering?
Look what I found.
https://www.lumintoponline.com/lumintop-fw3a-triple-p1492292.html
Hmmm… I click the link & it take me to the Tool AA 2.0
But your link clearly says fw3a-triple.
Either they are booking the page or they are making fake news :smiley:
