I could, probably should... I think I'm in troubles with Barry, maybe Tracy, Hank, just to mention a few... PM me - I'll really try to answer very soon.
I discovered this forum 7 years ago, but I didn’t “get it” back then, as much I do now. man did I missed out
The history behind the Q8 is intriguing, thanks for sharing Tom E.
RampingIOS V1 was made by Tom E, based on Narsil. RampingIOS V1 and NarsilM are both divergent branches of Narsil. About 98% or 99% of the code was written by Tom E.
RampingIOS V2 is the same thing, but I added and changed some things at Emisar’s request.
RampingIOS V3 is has completely different origins; I created it as a parallel fork of Anduril.
It’s almost entirely by Tom E. I only made like 1% of it (he used some short header files I wrote). It’s just barely enough that I can bother manufacturers about following the license, instead relying on Tom to do it. He’s pretty busy.
The M43 firmware was created by INFERION at Fonarevka. It’s a custom version of his Indigo firmware. DrJones and BLF were not involved.
The BLF 348 AAA flashlight is still in production with a Nichia NVSW219BT LED.See https://www.gearbest.com/led-flashlights/pp_554388.html?wid=1433363#goodsDetail
And the Sofirn C01 with Yuji led is not in development anymore, in the meantime even sold out.
Tom E.
“”and just plain old age to deal with as of late which all doesn’t help.“”
Simple cure there lad.
I’m 77 yrs.
Just walk along any area on a warm sunny day. Beaches/Foreshores are perfect.
Peruse the lithe beautiful body’s. Thinking back 60 yrs or so.
It puts a spring in your step and a twinkle in the eye.
NOT… a “dirty old man” Just reminiscing a little.
we were All there once.
I’ve got 8 Granddaughters from 11 yrs to 33yrs.
So they keep me young’(ish)
Have a great one hey.
I have a question. Will there be a BLF zoomie flashlight? A big zoomie like Uniquefire 1405 or 1508 ? I would love to buy it. I am too stupid come up with an original design, but since this forum created a BLF lantern, a BLF GT thrower and a BLF Q8 soda can flashlight + a bunch of other flashlights, making a BLF zoomie should be possible as well.
There was the Cometa a few years ago that used Toykeeper’s firmware. Frankly, zoomie are a style of light that is not so great to use. You get full brightness with a wide beam and maybe 1/4 1/3 brightness when focused tight. I keep my Cometa in the box.
Really cool idea!! A bright zoomie. Maybe multiple color leds and shapes you can make…?
Yeah, I have a few zoomies, and I never use them...
(By the way, I think you have the highlighted part backwards.)
I wish you would get full brightness with a wide beam!
No, I got it right. I measured 810 lumen on wide angle. As you narrow the focus the output drops to 270 lumen. The battery is still drawing the high amps and the led is still generating lots of heat, but you only get a fraction of the lumens. Hmmm, it’s exactly 1/3 the output so that’s a 66% loss in brightness.
I'm sorry, but that's not how zoomies work.
EDIT:
Zoomies are brightest in throw mode.
They are very dim, in comparison, in flood mode.
I own several zoomies, and have read about them on BLF for years.
I’m sorry, but that’s not how zoomies work.
EDIT:
He’s just using the wrong word. What he means by “brightness” is the total lumens output, which is definitely lower in throw mode, because of various losses. Some of the losses are inherent in the design, and some are because of low quality parts and/or bad design.
He's just using the wrong word. What he means by "brightness" is the total lumens output, which is definitely lower in throw mode, because of various losses. Some of the losses are inherent in the design, and some are because of low quality parts and/or bad design.
Now you both have it wrong.
A zoomie will output many more lumens in throw mode than in flood mode.
Am I the only one on BLF with zoomie common sense?
More lux, less lumens!
I may have failed to detect the presence of a joke. Not sure.
In any case, zoomies make more lumens in flood mode, and more candelas in throw mode. Usually the difference in both cases are quite large.
For example, I measured a classic SK-68 recently:
- Floody/wide mode, Eneloop:
- High: 67 lm
- Low: 18 lm
- Throwy/narrow mode, Eneloop:
- High: 37 lm
- Low: 10 lm
About a BLF zoomie, that sort of happened once, and it was a disaster. It was the CPFi Cometa, which was known for destroying itself as soon as a battery was inserted. Also had a whole bunch of other issues, and IIRC it resulted in Banggood firing Neal and changing the company it contracts to build Astrolux products, and several threads were shut down on BLF.
I have one of the lights the Cometa was trying to clone though, a modded Jax Z1. It’s pretty nice for a zoomie. Here’s a beamshot:
Okay, I guess I got it wrong...
Looks like the joke is on me.
"More candelas in throw mode" must be why throw mode looks much brighter.
I thought brighter means more lumens, but clearly it doesn't.
hey,
First of all, a huge thank you to everyone involved in getting these projects out the door. This is the kind of community that really works together as a team and creates great innovative light products.
However, how come there was never a “v2” version of a BLF flashlight? I don’t mean updated emitters or new firmware, more like a new version of an existing BLF flashlight? Is it because BLF creations are always perfect (of course they are!) or they are simply without any features that need to be introduced? Or is it easier to just create something entirely new?
Thanks for everything you guys do.
The BLF X5/X6 was actually v2 of the original BLF EE X6.
Fireflies replaced the E07 with E07 v2. And before that, they updated the ROT66 to sort of a v1.5.
It could be argued that the Emisar D1/D1S and GT-Micro/GT-Mini are v3 of the BLF X5/X6.
The Emisar D18 is a lot like Meteor v2.
Reylight brought back the old Ti Triple in the form of the new Dawn. It’s a v2.
There are often clones, too… like when the BLF GT came out, it created a whole category of clones.
The Convoy S2+ is basically v2 or even v3 or v4 of its lineage.
The Astrolux S41 has been revised as S42 and S43, though admittedly both newer models aren’t much like the original. The original was more like v2 of the BLF A6.
Etcetera.
Things keep moving; they just don’t always have an explicit “v2” on the label.
Maybe the clearest V2 would be the currently made Lucky Sun D80, thanks to the dedicated effort of TheOnlyDocc: there was a BLF version of the D80 a few years ago that had somewhat better firmware on the driver, a DTP board and a better led, and now Lucky Sun is prepared to allow extra hardware changes too and there will be a new version with a better heat transfer, improved tail section, and a completely new Lexel designed driver running Bistro. The looks and dimensions are unchanged from the original D80, so I call that a BLF D80 V2
