XHP50.2 J4 4000k output test by Texas_Ace - Really impressive improvement from the last gen
40 posts / 0 new
KevinZA1988
KevinZA1988's picture
Last seen: 10 hours 34 min ago
Why don’t you just go for Luxeon V’s then? You will get close to 7000 lumens with the stock setup, you will get a much nicer beam, and around 2min turbo before it gets too hot. I did it with mine and it’s still a USABLE and very bright light! With spring bypasses you should in theory get 8000 lumens with a total of around 25Amps. And you will have more throw than the XHP50.2 emitters. To me that’s important because the Q8 already has a very usable spill.
Acebeam L18, Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Olight Baton 3, Olight Warrior Mini, Olight M2R Pro Warrior.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Texas_Ace
Texas_Ace's picture
Last seen: 5 hours 33 min ago
Wieselflinkpro wrote:
I am thinking about using the 3V XHP50.2 in the Q8. And to keep it safe I would use AWG 22 with 10-15cm length.
AWG22 should have 0,00548ohm resistance at 10cm length. For 48Amps, it would be a voltage drop of 0,26V.
What do you think about it? How long would you make the AWG22?
Is it necessary to bridge the battery springs to protect them from overheating and melting?
If your only concern is not burning out the LED’s then no worries, they can handle even full power with heavy wire as others have shown.
The only reason to use thinner wire is to reduce the output / heat. Although in this case it will not help much, it will still get stupid hot, stupid fast.
yoosefheidari
Last seen: 2 years 3 days ago
hi
can i run a xhp50.2 continuously at 5 ampere and 6 volts for many hours with a very very good heatsink?is that harmful for led lifespan?
Texas_Ace
Texas_Ace's picture
yoosefheidari wrote:
hi can i run a xhp50.2 continuously at 5 ampere and 6 volts for many hours with a very very good heatsink?is that harmful for led lifespan?
As long as you are using a DTP copper mcpcb with a good heatsink that should be ok.
The lifespan will be reduced compared to running it at spec but we are talking 10,000’s of hours here, so doubtful you will notice and you can just replace it if it dies at that point.
Natewar
Natewar's picture
Do you happen to have the 3v version specs ?
JasonWW
JasonWW's picture
Last seen: 12 hours 30 min ago
Natewar wrote:
Do you happen to have the 3v version specs?
What specs do you need?
Output is basically the same except the amperage is double. Plus this 3v version is more durable and can run fine on FET drivers.
Natewar
Natewar's picture
JasonWW wrote:
What specs do you need? Output is basically the same except the amperage is double. Plus this 3v version is more durable and can run fine on FET drivers.
Yes it’s a great emitter I have a few running at 18ish amps on mosfet drivers was just looking for a chart didn’t know it was quite as simple as just doubling the amps
Texas_Ace
Texas_Ace's picture
That is what they do in the datasheets, they only measure one voltage and then just calculate the specs for the others.
JasonWW
JasonWW's picture
That’s what I do as well. 12v version, cut amps in half. Big Smile
