Thank you very much! People here are so helpful!
My Airpro DC7 arrived and I am very pleased to say the least. I just ordered a second one from Amazon Promo.
I love the Type-C charging.
Excellent deal IMHO.
Yes, a real Q8 knock-off. The Amazon seller who seemed quite knowledgeable about this light responded to my question about it being like a Q8. He pretty much admitted it's a Q8 knockoff, and I suppose, we should take it as a complement, at least I do. I doubt it's using NarsilM, though it's possible they used it and modified to their needs. He said they wanted a simpler UI for the more average customer.
The OP author posted a review on Facebook, group he admins, couple days ago and I commented on it there. Strange he does not even care to mention the Q8 similarities??
If anyone is capable who owns one, cares to take a peek at the driver, we would be very interested in pics. Love to see if it's our driver design as well, but wouldn't be the first time. I really like what they did with the styling and USB-C charging, though the SP36 might be a better option. Was considering getting one, if only for curiosity.
Any owner know if the bezel is SS like the real Q8? Can't tell from the pics or specs.
Edit: Price went up and promo code no longer is working . Wow! That was fast!
Ohhh - just saw they suggest putting the manual in the tailcap. That was definitely a joechina original idea...
Hhmmm. I would just like to see a little mention that we (BLF) were behind the idea of this one, just a weee bit...
LEDs: XPL-HI dedomed LED’s 6500k
I guess I’m being picky here, but the above is incorrect. The XPL-HI are not dedomed, they are domeless. Dedomed implies they originally had a dome which now has been removed, usually resulting in horrible tint shift.
Sorry, should have mentioned - nice review! Thanks!
Couple minor issues/questions:
- you mention the light is powder coated. That would be pretty bad if it is. Pretty much all these lights are anodized, not painted. Anodizing bonds into the metal, resulting in a strengthening of the surface.
- as Mike C says, we call these type of LED's "factory dedomed" sometimes, or simply XPL HI's, by their true name - domeless
- you did mention the BLFQ8 - could you take a side by side pic of the two?
- could you take a pic of what the driver contact side looks like? You should get easy access to it.
- is the bezel true Stainless steel like the Q8?
- you mentioned the ring around the switch is aluminum. The Q8's is SS - are you sure of the aluminum?
- compared to the BLF Q8, do you have pros/cons?
Thanks!!
Yes, a real Q8 knock-off. The Amazon seller who seemed quite knowledgeable about this light responded to my question about it being like a Q8. He pretty much admitted it’s a Q8 knockoff, and I suppose, we should take it as a complement, at least I do. I doubt it’s using NarsilM, though it’s possible they used it and modified to their needs. He said they wanted a simpler UI for the more average customer.
If anyone is capable who owns one, cares to take a peek at the driver, we would be very interested in pics. Love to see if it’s our driver design as well, but wouldn’t be the first time. I really like what they did with the styling and USB-C charging, though the SP36 might be a better option. Was considering getting one, if only for curiosity.
Any owner know if the bezel is SS like the real Q8? Can’t tell from the pics or specs.
Ohhh - just saw they suggest putting the manual in the tailcap. That was definitely a joechina original idea…
Hhmmm. I would just like to see a little mention that we (BLF) were behind the idea of this one, just a weee bit…
Yes … The bezel ring is SS. I am not equipped to dissect my light but I must say the build is top notch in my opinion, I own three O8’s to which I base my comparison. All in all a very nice homage to the Q8 “King of Can lights”.
Interesting knockoff that looks nice. Surprised the promo period already ended especially considering the Q8 is still on sale for $45. Nevertheless the slight update over the Q8 with the usb charging is demanded by many but IMO the silicon flappers they use to seal them never, ever work as intended and the IPX7 rating is really IPX6. I’d never purposefully submerge a silicone flapper light. Watched a video of a guy who destroys his Olight X9 testing it’s water resistance in a 1m pool. Flashlight filled with water and I expect the same result from any light with a silicone flapper.
Other than that, it’s a nice light and hopefully a compliment to the Q8
weklund - thanks for the info! Could you take a pic of the contact ring, driver side facing the batteries? Wondering if it's screwed down, glued, etc.
For under $45, I'd buy one, but at $75 - little pricey... Ohh wait. I see a $25 coupon right on the page, interesting.... So $50
The Amazon seller … responded to my question about it being like a Q8. He pretty much admitted it’s a Q8 knockoff …
I didn’t get an answer on Facebook yet, though it says the question was seen 3 days ago. So I asked on Amazon. Amazon’s question system is awkward at best for this kind of thing, but maybe it’ll work? If not, I can try some other method.
Yea, searching I can't find anything on the brand name, not yet, but funny this DC7 model was listed back in January so it's been on Amazon for a while.
weklund - thanks for the info! Could you take a pic of the contact ring, driver side facing the batteries? Wondering if it’s screwed down, glued, etc.
For under $45, I’d buy one, but at $75 - little pricey… Ohh wait. I see a $25 coupon right on the page, interesting…. So $50
Easy access … screwed not glued. I loosened the screws on mine and the contact plate is free.
Ahh, that's cool then. In the upper left I see a board mount, probably for the USB-C connector.
If you got it loose anyways, is it loose enough to pull out and take a pic of the other side? Don't try unless you are comfortable with it - don't want you to risk messing anything up. Ohh, do be carefuly with those screws. They tend to strip easy, usually...
Ahh, that’s cool then. In the upper left I see a board mount, probably for the USB-C connector.
If you got it loose anyways, is it loose enough to pull out and take a pic of the other side? Don’t try unless you are comfortable with it - don’t want you to risk messing anything up. Ohh, do be carefuly with those screws. They tend to strip easy, usually…
Here you go …
Ok, thanks again! It's clearly our FET+1 design with the good 7135, just not sure of the MCU - can't make out the labeling.
Ok, thanks again! It’s clearly our FET+1 design with the good 7135, just not sure of the MCU - can’t make out the labeling.
Yeah, I can’t tell either. With the USB port pointing south, it looks like there’s a FET and a 7135 to the west, a 14-leg MCU in the center, and some other 8-leg chip to the east. I can’t tell what the center or east chips are. It looks like the 14-leg chip is probably in control though, since it has traces going to the FET and 7135 chips… so either it’s not running a derivative of Narsil, or they did some work to port it to another MCU.
Just got mine today, pretty nice. Only tried it with 1 cell from my MH20, so didn’t crank it up to 11 or anything, but the basics seem to work.
Curious, what’s different about the UI, that Airpro wanted to “simplify”, vs the Q8?
Just ordered another as a spare :person_facepalming: , and would’ve gotten yet another to gift if I could’ve snagged ’em at 43 vs 51.
Still, build quality looks nice, threads are nicely lubed and gliiiiiide nicely, tint/color is pretty good… all in all, I’m happy.
A Q8 with USB charging would make a perfect gift :+1:
But this is in dire need of experts opinion of quality of the changes, for example a “breathing” led button did not seem necessary and may introduce unnoticed problems.
Q: This looks like a sofrn q8 copy, adding charging and slight style changes. why did you copy the sofirn q8?
A: Thank you for your questions. Yes it is a little similar with Q8. But we updated the programe which had simiplified the operation by users. Target market is different, it is aimed for daily use at home or outside. And designers make many changes inside and outside of the flashlight. But quality is without change. What we can say that we have NO PROBLEM with sofirn Q8. So, feel free to buy and we offer 1 year worry-free guarantee
I dig the Green Eye that never sleeps … great for the nitetime locator. I am very pleased with mine so far.
That’s my only gripe. I hate “breathers”. Constant-on, or beacon, great. Breather, nope. Turned mine back off again.
Nighttime, that “movement” would just be too distracting. Even the “beacon” on my MH20’s switch is too distracting.
Constant-on tailcap of my Cometa (or Q8)? Just fine. Go figure…
They “Simply” didn’t want to give credit due for license of software so they pretended to have changed it
