Imagen you find yourself in that “Oooh $h!t” moment and you pull your light from your pocket and you find you left it in E-lockout. Time yourself to see how long it takes to get it into the fight.
lol I agree the electronic lock-out is a double edged sword. had the light once deplete fully in my pocket because it turned on and I never noticed. Then after using the E-lockout I also realized that it really defeats the purpose of the tactical tail switch and all you gain from instant turbo/strobe is lost on the 3 second E-lockout unlocking.
That being said, is the main issue you have with it that it has a side switch and isn’t a tail switch only?
The M2R is tail cap twistable so that’s not really a valid point
I haven’t personally tested mine to see if the tail switch overrides the E-lockout but I suspect it does not. Especially considering you can set the tail switch to momentary strobe/turbo only and that it has a significant depression required to activate the second stage of the E-switch I definitely agree that’s a very poorly designed E-lockout on Olights part
It couldn’t have gotten very hot in that fire. The switch internals and reflector are made out of plastic.
I found a 3D maglite in the woods. Looked like it had been there for years, but it turned on first try. The main issue for me on maglites has been the switch. They fail with constant use. Usually the plastic switch cover goes missing. Once that happens it’s not long before crap gets in there and it starts to fail. Maglites are very reliable if you never use them (or lose them!), but not with heavy use.
Go get some good tactical training, it’s clear you have very little. I’m not trying to insult you or anything. Take it from Olight the tail switch does not override the E-lockout. Which could mean the difference in a high stress situation. Fractions of a second usually mean you loose your life.
That’s the WHOLE point!
In a life or death struggle, you can’t say to the bad guy “wait until I get my light in order before you kill me”.
Best true EDC tactical light in my opinion is my Malkoff Bodyguard. Not cheap but extremely dependable and will most assuredly get the job done when called upon. No brainer tail switch UI with plenty of lumens to place on target … check it out.
Unless i checked the light myself (solderjoints, wires, assembly. . .) i would not trust any of them with my life.
You will find bad assembled lights, wrong screws, bad solderjoints, potential shorts from sharp edges. . . from all companys regardless how much money you pay.
It has a reason why parachutist wrap their parachute themself. If your live depends on it, there are not a lot of people that you can trust like you can trust yourself.
Sorry didn’t mean to come across accusatory, I just meant that in regards to bypassing the Olights poorly designed lock-out feature you do have the option to twist the tailcap to lock the light out and then instead of waiting for the E-lockout you could just twist it closed to unlock your light.
I thought that’s what you meant by the tailcap twist but I also believe you might have been referring to tactical lights that have a tailcap twist as their lockout function by design?
yes we’re both in agreement Olight made a poor choice with their E-lockout but bypassing the E-lockout by unscrewing the tailcap could solve that problem don’t you think?
lol I’m also from Canada so you never know… If you ask nicely enough the perpetrator might just let you unlock your tactical flashlight
Not really, do you think you could remember what mode you were in before you unscrewed your tailcap while fending off an attacker or confronting an invader in your home?
I lived in Canada as well (I’ll be watching the HABS tonight) for a couple of years, my mom was born there, and I still have family there.
PS Paul Byron must have been trying to unlock his M2R in the game against Florida the other night. I guess that’s because Weegar’s not from Canada :person_facepalming:
I don’t agree. First, I just have to point out that I’m switching topics from flashlight to weapon light, and neither of which is a perfect substitute for the other. Second is that while it’s hard to make the case that a weapon light is undesirable (although there are certain negatives, like weight while carrying it and an extra thing you train yourself to do, while drawing, before pulling the trigger), I just don’t think it’s necessary, at least not all the time. I also don’t think it’s practical to identify a target “100%” to shoot back — what if they are wearing masks or motorcycle helmets, for example?
In the dgu’s I’ve read about and seen videos of, the attackers confront their victims on the street, in a store, at the victim’s home, usually somewhere where they can make a quick escape from with easy access to a street, and the same aggression by the attacker that prompts the would-be victim to draw his weapon makes the victim’s need to use the weapon just as unmistakable.
Now if you want to talk about some of the raids that police or military do, going into a dark house or bunker with a team, I’m not going to say the same thing at all. Of course that’s a totally different situation with different requirements and different objectives. But you did start the thread talking about my life and my family — none of which are police or military. Flashlights are neat and handy tools, but I wouldn’t stake my life on one of them unless I changed professions, and even then, I’d want to have some sort of back up system.
Good luck tonight! 1 point out for the last wild card in the East will be a big battle!
The M2R has an electronic tail switch which only has two modes and has to be changed with a 2-step process. It comes stock set as:
half press on tailswitch = momentary turbo
full press on tailswitch = turbo on
the other mode (which I leave mine in)
full press on tailswitch = momentary strobe
so in the event of an emergency you’d have to twist the tailcap then smash the tailswitch and you’d be guaranteed either full turbo or strobe
That’s why I was confused nobody liked the M2R. The lockout sucks but I thought the tailswitch design was great - when lurking in the dark I consciously half press the tailswitch and I’ve got turbo but under a stressful situation and I can’t think I just mash the button, hold it down and I’ve got strobe with no fiddling about what so ever
Imagine coming home to what’s supposed to be an empty house and you hear rustling inside. Do you immediately go investigate guns drawn?
———This exact situation resulted in a US man shooting his 8 year old daughter who got home early and hid in the closet to scare her parents. 100% confirmation of the target with a flashlight could’ve easily prevented that
I imagine if it was the middle of the night and you heard sounds of an obvious B&E that having guns drawn would be exactly the position you’d want and 100% identification would be less concerning.
For the obvious B&E WML makes sense
For investigating noises at night kind of situations I’d go flashlight with weapon holstered or at the ready
