Measured the output cap value with my ZT102 multimeter, 154,1µF. Is that a tantalum capacitor?
Wellp, went to the Alpha & Omega Semiconductor site to look for AON7403 alternatives:
I mean, you could get this too:
It’s in the same package, and has even low resistance at 6mOhm even at VGS = –2,5V.
Nice find BlueSwordM, also in stock at Arrow (free ;-) shipping): https://www.arrow.com/en/products/tpn4r712mdl1q/toshiba
Also cheaper than the AON7421, but way slower switching speed though. tr + ton + tf + toff is 198ns for the AON7421, 617ns for the TPN4R712MD.L1Q, and just 42,2ns for the AON7403. The buck converter frequency is probably ≈300KHz, I wonder to which point do these parameters matter.
I'd like to hear some experts first. :-D
Besides changing the current sense value my wild guess is that I should swap the switching MOSFET, the inductor and maybe improve input and/or output capacitance (?). This should allow the buck driver to operate reliably at much higher currents because of much improved output noise and reliability.
Anyone?
That buck controller is an XC9221, you’ll find guidelines and the relevant formulas in the datasheet here.
I think 4.7µH is already on the low side for 300kHz, any lower might cause stability issues, but if you can fit a bigger size inductor anyways you can up the current rating at that value.
I don’t think switching speed of the FET is that big of an issue at 300kHz, but what matters is the input capacitance (recommended <1500pF), otherwise the controller can’t drive the gate fast enough. (That’s where the Toshiba shits the bed)
btw, Vishay and TI have very good FETs (like the CSD25402Q3A )
PS: If you’re using this in a 2S setup anyway, does the Vgs@2.5V matter that much? I don’t think so
Thanks for the input kikkoman, seems the XC9221 wasn't designed for higher than 3A output and I want to make it go a lot beyond }D that LoL. Thank God at least the schottky O:) is generous.
Both the TPN4R712MD.L1Q and the AON7421 have about 3x the maximum recommended input capacitance listed in the XC9221 datasheet. The CSD25402Q3A is a nice find but it is not available in single pieces at Arrow, so I have to keep looking.
There’s its brother, the CSD25404Q3 - slightly lower Rds, slightly higher gate capacitance (but still quite low), and it’s a bit pricier. 0.95€ for 1.
I really can’t tell you though how ‘set in stone’ that current limit is. There’s no internal current limit, so aside from external components (= available space), I guess the gate driver is the one limiting factor.
Thanks again kikkoman, I was even then hopelessly looking at the PowerPAK 1212-8 section at Vishay.
Guess will have to try that CSD25404Q3. The input capacitance is specified at 10V, it should be a bit lower at a bit less voltage, doesn't it? Also, the QX9221 shouldn't complain if a little bit above 1500pF…
To round this off, took a peek at Murata's inductor catalog. Their FDA1254-H-4R7M=P3 seems to fit the high current bill (LoL with the model naming). €2,01 a piece… :facepalm:
Cheers ^:)
Just ordered 3x FDA1254-H-4R7M=P3 inductors and 3x CSD25404Q3 MOSFETs. Didn't asked this before, but I guess improving input and output capacitance is also advisable, doesn't it?
Stock input capacitance is 22µF and I have 90+ pieces of capacitors like the stock one inside a drawer. Also a handful of 47µF tantalum caps which may go well at the output…
Will have to put a name to the badass, maybe LD-29.9 LoL.
Mon, 02/11/2019 - 06:23
There’s no real downside to increasing the input capacitance I think, but output is different. If the ESR is too low, you’ll get load transient issues. I wouldn’t go overboard with that.
If you have a scope, you can check if output ripple is within acceptable limits (if it is, then there’s no reason to increase C_out).
Free overnight shipping @ Arrow is great but there are distributors that are cheaper in the end (even with shipping) where comparable inductors cost 1/4 of the price.
Thanks again for contributing kikkoman.
Could add another input capacitor in parallel without much trouble.
What do you mean with output load transient issues?
No scope right now but since I aim for 3x the stock current output, I'll fit some extra capacitance.
With regards to getting a scope, will have to consider this. Something affordable :-D and good. I have not much idea of the features I should mainly care for with the exception of price LoL.
Examples?
Cheers ^:)
Just noticed I'll have to build a saddle for the MOSFET swap LoL:
:FACEPALM: O:) :P
Connected my small 219B plus heatsink testing mule to it and supplied power (≈8.2V) with DC supply, sticking a normally closed push button in the middle for mode change.
Of course I set some current limit in the supply just in case. The emitter started being lit very faintly, and its output started ramping up until the supply hit the current limit at more current than it should pull with the stock sense resistor value. I used the switch a few times and it seemed to enter some sort of weird strobe mode at some point, but continued hitting the switch. I raised the current limit a bit and then I left it doing what it was doing once or twice more for some seconds and all of a sudden it all stopped, with some very subtle burning smell I'd say.
Could it be that the buck converter was unable to properly drive the MOSFET gate?
I have not dismantled the driver corpse yet LoL.
O:)
I was toying with the idea of modifying another one of these, found a well suited inductor in the Bourns SRP6050CA-4R7M. However, I have a few qualms with the newer LD-29. The AON7403 MOSFET's low VGS (3 - 4V) performance seems much worse than that of the FDS4435 according to datasheet curves. I wonder how much of an impact will this have for 1S operation due to the much higher input current handling. Not being a scaremonger, just a little tired of burning stuff up. It would also help if manufacturers would stop spoiling their products (are you hearing LDCH?).
Cheers
Been peeking into some small package p-channel MOSFET datasheets with low input gate capacitance. There are some better offerings over the stock AON7403, the Infineon IRFHM9391TRPBF for example. However, all of them exhibit noticeably lower performance at less than –4.5V of VGS, and already a lot lower at –3.5V. I am surprised at how this driver did not have some problems on high mode with less than 4V of input, but of course this is due to the relatively low input current. Sucks, really.
Sat, 04/06/2019 - 20:53
Hi,
you may have a look on 3x3mm footprints I found there some way better P-FETs
you can PM me if you found the right
a slight hint which makes you think its a N-Channel buts its indeed a P-FET
I have looked also at ultra low Vgs N-channel FETs I found one that has down to 1.5V almost no increased Rds
btw your infineon datasheet link is not working
it is a really bad choice looking on Vgs graph for 1S drivers
I have fixed the link Lexel.
What's this?
The XC9220 which is onboard the LD-29 drives p-channel MOSFETs (I think or believe it uses that).
those are 2 very good fets
the one with red graph P-channel
the other N-Channel dont mix em up together
I dont write the type as its sort of a lot research I did to find them but you should be able to find them
if you look for an 1/2S replacement FET you need one that stays at a relative stable Rdson down to 3V better 2.5V
