Latest release Vapcell 21700 5600mah 12.5A battery
The banggood may have an advertising partnership with Google. :slight_smile:
Thanks you very much
We will send sample to HKJ for test, hope he will test it
because many batteries send to him, waitting to test :weary:
HKJ tests all rechargeable batteries and other products
He is a great man :+1: :+1: :+1:
I do often have some queue, at the current time it is very bad for >2800mAh batteries, but I only have one Vapcell branded battery in queue at the current time and it goes on the tester very soon.
Wow :open_mouth: , HKJ is here. He reply so quickly…
Thanks very much
Maybe I misremembered. Many users or testers contacted us for samples.
I checked it. I remember that we have shipped red 18650 2800 MAH 25A and 21700 4500 MAH 20A.
I wonder if you haven’t received the samples. Thank you
Thank you again for your test
We should send you fewer batteries than 2800 mah. :smiley:
I do not have a red 2800mAh from your, but I have a black I bought myself, it is tested, but not published yet.
The 4500mAh is the one I have left in queue.
I test most batteries I get or buy, but a few do not get published for different reason: they get to old before I can test them, another reason can be a fault on my test station, (This happens a few times each year), sometimes I can use the data, sometimes not. And sometimes I makes mistakes when testing.
If that is the VTC5D rewrap I am interested. I just tested that last night myself at 3.5A discharge
Well, thank you very much for your information.
red 18650 2800 MAH 25A ,it’s lost. :cry:
If you want to test vapcell batteries or other batteries that we have in stock, please contact me and I will arrange for shipment to you. :slight_smile:
I’d like to send you a lot of batteries for testing. I’m afraid you’re too busy.
So some battery samples haven’t been sent to you yet.
black 2800mah is the VTC5D rewarp
Red 2800mah is the P28A rewarp
:slight_smile:
With >2800mAh I have a couple of months queue, but the test station for the smaller sizes is basically empty. I have been using it to test cheap batteries on (I do not care about the <=2800mAh rating for cheap batteries).
The reason for the split at 2800mAh is to always test same capacity on same test station, this gives the absolutely best comparison (There is a small difference between the two test stations).
ok Thanks
Found the 16340 cells on the Vapcell store and ordered 2 pairs to check :slight_smile:
Thanks, ordered also, let’s hope we finally have some new decent 16340s.
Me too! Looks good.
Indeed. I was not a fan of 16340 format. Too close to 18350 and way less capable.
But this cell significantly reduces the gap.
And add availability of USB rechargable cells - 16340 becomes interesting.
But 16340 lights are sooooo nice to EDC…
Thank you very much. Cassiel released the 16340 in Ali.
What is EBC? Thanks :person_facepalming:
EDC = Every Day Carry
Another words, a light that’s small enough to carry around all the time.
I EDC 2 kinds of lights:
  • neck ones
    • 16340 is far too large already….but nevertheless acceptable
      • I’ve worn lights up to 25.4 mm in diameter - so even 21700 would do. :smiley:
  • backpack ones
    • Lumintop GT Mini 18350 for quite some time already
    • the size difference between 16340 and 18350 is meaningless here
I really wish I had a better driver in my Utorch S1 Mini. BLF firmware, FET, good cell, quad E21…ah, that’s a nice dream. :slight_smile:
And some really low diameter 16340 light, say 19-19.5 mm would be even better. :slight_smile:
I just ordered a pair of 16340 to try in my Olight S1RII. The mah numbers on these look great.
